Talk about (almost) anything
by DFX2KX » Tue Aug 26, 2014 10:26 pm
So, um, I dropped my Gamebuino...
- GBcrack.jpg (35.01 KiB) Viewed 6294 times
Whoops! Still works, even after the fall from my backpack. This does seem to be a bit of a weak point in the case, however, weak being relative.
I'm going to leave it attached until I can get some plastic safe CA to patch it.
DFX2KX
by Matrix828 » Tue Aug 26, 2014 10:31 pm
When Rodot launches the online store to buy new cases you'll be able to replace it
Matrix828
by DFX2KX » Tue Aug 26, 2014 10:39 pm
Matrix828 wrote:When Rodot launches the online store to buy new cases you'll be able to replace it
indeed. Was looking at making a custom acrylic case anyway, XD room for some more buttons.
DFX2KX
by rodot » Wed Aug 27, 2014 9:53 am
I dropped my Gamebuino from 2 meters (~6 feets) about 30 times, and threw it against the walls of my rooms without managing to break it (don't try this a home). I'm sorry that your broke on the first drop
The good news are that as Matrix828 said you'll be able to get a new, colored case. Moreover the colored cases will be 3mm thick (instead of 2.5mm for the clear ones), so they should be slightly more resistant.
by DFX2KX » Wed Aug 27, 2014 9:42 pm
rodot wrote:I dropped my Gamebuino from 2 meters (~6 feets) about 30 times, and threw it against the walls of my rooms without managing to break it (don't try this a home). I'm sorry that your broke on the first drop
Indeed! I think it managed to land perfectly on the corner of the panel, and that's why it broke. It still works, so it's not that big a deal XD When I noticed it, I was expecting something else to be broken, but nothing is (that I can tell, have no spi or I2C stuff to test
DFX2KX
by Skyrunner65 » Thu Aug 28, 2014 11:50 am
Jesus! What did you make these out of?
Thought about cases: are you going to have a Game Boy themed case? Because that would so work for me.
Skyrunner65
by rodot » Thu Aug 28, 2014 11:55 am
Skyrunner65 wrote:Thought about cases: are you going to have a Game Boy themed case? Because that would so work for me.
I understand the idea, but I don't see how that would be possible with the laser-cut acrylic?
by DFX2KX » Thu Aug 28, 2014 11:14 pm
Skyrunner65 wrote:Jesus! What did you make these out of?
The case is made out of a plastic called acrylic. It's strong, light, and reasonably cheap. It's a bit brittle under the right conditions, but overall, it's a good plastic.
DFX2KX
by Drakker » Fri Aug 29, 2014 12:33 am
You could use a 3D printing service like shapeways if you want to print a Gameboy-like "wrap-around" case. Rodot made a CAD file available of the Gamebuino, so if you can use CAD software, designing a complete case and getting it printed would be easy. If the design is good, other people might want to order it too (which means you'd get a small part of the profit every time somebody orders one).
Drakker
by qubist » Fri Aug 29, 2014 1:51 am
You could try
Tinkercad. It is easy, free, and powerful! Give it a try!
qubist
Return to General forum
