Page 1 of 1
[HELP]Gamebuino Raspberry I2c
PostPosted: Sat May 27, 2017 10:04 am
by pharia
I'm trying to connect a Gamebuono with Raspberry Pi 2 through I2C connection.
I connected them as follows:
Gamebuino                        Raspberry
GND      <-------------->     -
3V3      <-------------->     -
SDA      <-------------->     SDA (GPIO 2) (Pin 3)
SCK      <-------------->     SCK (GPIO 3) (pin 5)
I did not connect gnd and 3v3 because since they were already powered I think it was not needed
On raspberry launch
i2cdetect -y 1
But the gamebuino is not detected
On Gamebuino launch
#include <Wire.h>
  Wire.begin(8);                // join i2c bus with address #8
  Wire.onReceive(receiveEvent); // register event
  Serial.begin(9600);           // start serial for output
  delay(100);
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void receiveEvent(int howMany) {
  while (1 < Wire.available()) { // loop through all but the last
    char c = Wire.read(); // receive byte as a character
    Serial.print(c);         // print the character
  int x = Wire.read();    // receive byte as an integer
  Serial.println(x);         // print the integer
How can I do it? Thanks
Re: [HELP]Gamebuino Raspberry I2c
PostPosted: Sat May 27, 2017 6:13 pm
by Sorunome
Did you connect the grounds, though? To make sure that their ground level is the same.
The reson behind that is that voltage is only a difference in electric potential, and ground is just a reference point. The reference point of your gamebuino and the raspberry pi might be different, that is why you just connect the grounds.
Fun fact: Any data cable (audio, monitor, etc) you'll see does that, too :)
