Pixel aspect ratio
Pixel aspect ratio
Postby erico » Fri Apr 11, 2014 6:57 pm
A question of mine:
I was analyzing Myndale´s test of an image on a real Gamebuino (beta) against what I have on my monitor.
I believe my monitor has a pixel aspect ration (and in software too) of 1x1, a square pixel.
From the Gamebuino picture, if optics are not deceiving me, I get 6/7x1, so a slightly taller pixel.
Am I wrong? Can someone confirm the pixel aspect ratio on the screen of the Gamebuino?
Of course whatever it is is no problem, it doesn´t affect game design, it is more out of curiosity.
A comparison image goes bellow.
aspect test.jpg (83.67 KiB) Viewed 4494 times
Re: Pixel aspect ratio
Postby Myndale » Fri Apr 11, 2014 10:31 pm
The 5110 datasheet here...
http://skpang.co.uk/catalog/images/lcd/graphic/docs/User_Manual_ET_LCD5110.pdf
...states that the internal controller is a PCD8544. Its datasheet specifies an effective display area of 28.95x19.41mm:
http://serdisplib.sourceforge.net/ser/doc/goldentek.pdf
That matches my physical measurements exactly and results in an aspect ratio of 28.95*48/84/19.41 = 1/1.17, so your estimate was accurate to about 0.3% :)
Lots more info here: http://serdisplib.sourceforge.net/ser/pcd8544.html
Postby erico » Fri Apr 11, 2014 11:11 pm
That is a lot of hardware references, thanks for sharing the info.
Should be a good read.
Myndale wrote:...
The .3% may probably be from cropping and scaling the original photo, but I´m impressed myself on your results. I now know the true aspect ratio of it, thanks again!
