Image Converter
Re: Image Converter
Postby DFX2KX » Sat May 24, 2014 6:50 am
ripper121 wrote:you can generate a Map with sprites.
You use an 2D array of byte for map config
byte myMap[10][6] = {
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
now you can for every byte (in this map every 0) creat 255 Sprites
So you loop trouth the myMap and Draw the Sprits every 8 Pixel in x and y with,
gb.display.drawBitmap(x, y, bitmap);
Ah, okay! Thanks for that! (I imagine you could save a few ms by checking each time if the sprite in question will even be visible, and skip drawing it if need be)
Alas, I've gotten gray to (kinda) work! The Emulator can't handle that much flicker, but it works! great tool, I'm going to use the heck out of it.
DFX2KX
Re: Image Converter
Postby ripper121 » Tue May 27, 2014 1:39 pm
UPDATE:
-solve the bug if the image is smaller then 8x8 pixel
ripper121
Re: Image Converter
Postby rodot » Tue May 27, 2014 4:23 pm
ripper121 wrote:UPDATE:
Thanks for updating that nice piece of software! I just want to precise that the library needs the width to be a multiple of 8px, but it supports heights < 8 px.
Re: Image Converter
Postby ripper121 » Tue May 27, 2014 4:44 pm
Yes but the format B00000000 should be the range.
If you like you can put the converter to the Library ;)
ripper121
Re: Image Converter
Postby DFX2KX » Fri May 30, 2014 8:34 pm
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
Thanks, that turned out to be quite similar to what I did.
Also, just so you know. on Windows 7, the image converter likes to take the icon of one of the other applications on the taskbar, usually seems to be whatever the last thing I opened before the program itself was. It's not serious, just odd. I wasn't sure if it was supposed to have it's own Icon, of if my Windows is just deciding to act weird with it.
DFX2KX
Re: Image Converter
Postby ripper121 » Sat May 31, 2014 7:27 pm
Yes it's a bug but I don't know from where it comes. When you download the source you can see there is a gb logo icon.
ripper121
Re: Image Converter
Postby DFX2KX » Sat May 31, 2014 9:31 pm
ripper121 wrote:Yes it's a bug but I don't know from where it comes. When you download the source you can see there is a gb logo icon.
Well, at least it's not me!
DFX2KX
Re: Image Converter
Postby Skyrunner65 » Wed Jun 25, 2014 8:43 pm
Linux build?
Skyrunner65
Re: Image Converter
Postby rodot » Wed Jun 25, 2014 9:16 pm
Skyrunner65 wrote:Linux build?
A "please" doesn't harm. I made a Java based bitmap encoder, I'll upload it soon.
Re: Image Converter
Postby Skyrunner65 » Fri Jun 27, 2014 12:53 am
Sorry, I didn't think about it.
But Java-based? Yay!
Skyrunner65
Users browsing this forum: No registered users and 16 guests
