Here's a drop-in replacement for drawBitmap that supports clipping and all colors including grayscale (if you enable it). I've tested it with Crabator and it seems to work fine:
void Display::drawBitmap(int8_t x, int8_t y, const uint8_t *bitmap) {
int8_t w = pgm_read_byte(bitmap);
int8_t h = pgm_read_byte(bitmap + 1);
bitmap = bitmap + 2; //add an offset to the pointer to start after the width and height
#if (ENABLE_BITMAPS > 0)
/* original code
int8_t i, j, byteWidth = (w + 7) / 8;
for (j = 0; j < h; j++) {
for (i = 0; i < w; i++) {
if (pgm_read_byte(bitmap + j * byteWidth + i / 8) & (B10000000 >> (i % 8))) {
drawPixel(x + i, y + j);
uint8_t * buffer = getBuffer();
const uint8_t col = color;
const uint8_t bw = (w+7) / 8;
// clip
if (x >= LCDWIDTH)
return;
if (x + w <= 0)
return;
if (y >= LCDHEIGHT)
return;
if (y + h <= 0)
return;
if (y < 0)
h += y, bitmap -= bw * y, y = 0;
if (y + h > LCDHEIGHT)
h = LCDHEIGHT - y;
uint8_t x1 = max(0, x);
uint8_t x2 = min(LCDWIDTH, x + w);
#ifdef ENABLE_GREYSCALE
uint8_t g = y ^ frameCount;
#endif
// draw
uint8_t first_bitmap_mask = 0x80 >> ((x1 - x) & 7);
const uint8_t * bitmap_line = bitmap + (x1 - x) / 8;
uint8_t screen_mask = 0x01 << (y % 8);
uint8_t * screen_row = buffer + (y / 8) * LCDWIDTH + x1;
for (uint8_t dy=0; dy<h; dy++, bitmap_line+=bw)
const uint8_t * bitmap_ptr = bitmap_line;
uint8_t bitmap_mask = first_bitmap_mask;
uint8_t pixels = pgm_read_byte(bitmap_ptr);
uint8_t * dst = screen_row;
if (col == BLACK)
for (uint8_t sx=x1; sx<x2; sx++, dst++)
if (pixels & bitmap_mask)
*dst |= screen_mask;
bitmap_mask >>= 1;
if (!bitmap_mask)
bitmap_mask = 0x80;
pixels = pgm_read_byte(++bitmap_ptr);
else if (col == WHITE)
uint8_t inv_screen_mask = ~screen_mask;
*dst &= inv_screen_mask;
bitmap_mask >>= 1;
if (!bitmap_mask)
bitmap_mask = 0x80;
else if (col == GRAY)
if ((sx^g) & 1)
else
bitmap_mask >>= 1;
if (!bitmap_mask)
bitmap_mask = 0x80;
g ^= 1;
#endif
else // invert
*dst ^= screen_mask;
bitmap_mask >>= 1;
if (!bitmap_mask)
bitmap_mask = 0x80;
screen_mask <<= 1;
if (!screen_mask)
screen_mask = 1;
screen_row += LCDWIDTH;
#else
drawRect(x, y, w, h);
#endif
If you want greyscale then you'll need to define ENABLE_GREYSCALE (or just comment those lines back in), you'll also need to provide a way of passing in the frameCount variable.
As is usually the case with optimization this code tries to strike a balance between speed and code size. It currently adds about 400 bytes to the size of the function and runs my test blt code in around 1500ms.
