by Sorunome » Fri May 15, 2015 3:06 pm
Is it possible to execute certain code from RAM rather than from Flash?
I want to be able to flash a game with some other logic provided in the bootloader, so I thought of copying the flashing code to ram and running it from there. Is that possible with the AVR?
by Myndale » Tue May 19, 2015 5:52 am
Sorunome wrote:Is it possible to execute certain code from RAM rather than from Flash?
Not directly, AVR chips use Harvard architecture which uses separate storage and buses for data vs instructions. It is, however, possible for the bootloader to write code into Flash memory...that is after all what the bootloader is designed to do. If you look at the standard bootloader you'll see there is code that does just that using data it receives over the serial line, the Gamebuino bootloader also has a special function that games can call directly to program blocks of flash memory.
by Sorunome » Tue May 19, 2015 11:52 am
Myndale wrote:Sorunome wrote:Is it possible to execute certain code from RAM rather than from Flash?
The problem is that if i flash an entire game eventually the loop which calls the bootloader flash block thingy gets over-written, and I can't use load_game() as it only searches in the root directory.
by hannanbd » Thu Jun 04, 2015 8:56 am
This post is very nice and informational also .I have visited this website again and again to learn many things .Thanks to share with us this post .I know ,all answer are very essential for us .Thanks again for reading this post .
hannanbd
Users browsing this forum: No registered users and 38 guests
