by AntonyPrince » Tue Aug 12, 2014 2:51 am
Skyrunner65 wrote:I can't make this in Fedora 20. I have all the dependencies except for Glut (I have freeglut).
And just to make sure, I did it in both the gbsim-master/ and gbsim-master/gbsim directories.
What did I do wrong?
I had the same problem. You're missing one of the following (I forget which one I was missing that caused the problem.):
gcc-avr (or avr-gcc)
gcc
avr-libc
The "cc: command not found" error is because make can't find the particular gcc compiler it is looking for. cc is the fallback for gcc and cc doesn't exist either, hence the error. It's probably that you're missing gcc-avr or gcc. I could be mistaken though. Only reason I mentioned avr-libc was because I originally tried compiling on CentOS which is RHEL based as well and I had particular problems finding libsdl2-dev and avr-libc.
AntonyPrince
by Skyrunner65 » Tue Aug 12, 2014 11:45 pm
Thank you, but it gave me something else:
[iobst@teens ~]$ cd /home/iobst/Downloads/gbsim-master
[iobst@teens gbsim-master]$ make
make -C simavr RELEASE=0
/usr/bin/bash: git: command not found
make[1]: Entering directory `/home/iobst/Downloads/gbsim-master/simavr'
CONF obj-i686-redhat-linux/cores.deps
WARNING cores/sim_mega324.c did not compile, check your avr-gcc toolchain
make[1]: Leaving directory `/home/iobst/Downloads/gbsim-master/simavr'
make obj config
make[2]: Entering directory `/home/iobst/Downloads/gbsim-master/simavr'
make[2]: Nothing to be done for `obj'.
CONF sim_core_decl.h
make[2]: Leaving directory `/home/iobst/Downloads/gbsim-master/simavr'
make libsimavr run_avr
CC sim/sim_interrupts.c
CC sim/sim_gdb.c
CC sim/sim_cycle_timers.c
CC sim/sim_core.c
sim/sim_elf.c:32:20: fatal error: libelf.h: No such file or directory
#include <libelf.h>
compilation terminated.
make[2]: *** [obj-i686-redhat-linux/sim_elf.o] Error 1
make[1]: *** [all] Error 2
make: *** [build-simavr] Error 2
Apparently it doesn't know what the command "git" is.
Skyrunner65
by 94k » Wed Aug 13, 2014 1:03 am
Try
which git
in case it isn't installed you'll have to use your package manager to install it (git is extremely common, so you shouldn't run into problems there). If it is installed you might want to adjust your PATH.
94k
by Skyrunner65 » Wed Aug 13, 2014 3:32 am
Now it did this:
fatal: Not a git repository (or any parent up to mount point /home)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
make obj config
make[2]: Nothing to be done for `config'.
#include <libelf.h>
Skyrunner65
by 94k » Wed Aug 13, 2014 1:47 pm
You'll have to download the repository via git, try the following commands:
git clone https://github.com/33d/gbsim.git
cd gbsim
make
You may have to install additional dependencies (I needed libelf and SDL2 (try to install the packages with "devel" suffix))
94k
by Skyrunner65 » Wed Aug 13, 2014 2:55 pm
Everything went well, until "
glut.h" was not found as a file or directory.
I did get the devel version of libelf, and that got rid of some problems.
[iobst@teens gbsim]$ make
make[1]: Entering directory `/home/iobst/gbsim/simavr'
make obj config
make[2]: Entering directory `/home/iobst/gbsim/simavr'
make[2]: Leaving directory `/home/iobst/gbsim/simavr'
CC sim/sim_elf.c
CC sim/sim_irq.c
CC sim/sim_vcd_file.c
CC sim/sim_io.c
CC sim/sim_avr.c
CC sim/sim_hex.c
CC sim/avr_adc.c
CC sim/avr_flash.c
CC sim/avr_lin.c
CC sim/avr_twi.c
CC sim/avr_uart.c
CC sim/avr_spi.c
CC sim/avr_usb.c
CC sim/avr_ioport.c
CC sim/avr_extint.c
CC sim/avr_eeprom.c
CC sim/avr_timer.c
CC sim/avr_bitbang.c
CC sim/avr_watchdog.c
CORE cores/sim_90usb162.c
CORE cores/sim_mega1280.c
CORE cores/sim_mega1281.c
CORE cores/sim_mega1284.c
CORE cores/sim_mega128.c
CORE cores/sim_mega128rfa1.c
CORE cores/sim_mega164.c
CORE cores/sim_mega168.c
CORE cores/sim_mega169.c
CORE cores/sim_mega16.c
CORE cores/sim_mega16m1.c
CORE cores/sim_mega2560.c
CORE cores/sim_mega328.c
CORE cores/sim_mega32.c
CORE cores/sim_mega48.c
CORE cores/sim_mega644.c
CORE cores/sim_mega88.c
CORE cores/sim_mega8.c
CORE cores/sim_megax4.c
CORE cores/sim_megax8.c
CORE cores/sim_megax.c
CORE cores/sim_megaxm1.c
CORE cores/sim_tiny13.c
CORE cores/sim_tiny2313.c
CORE cores/sim_tiny24.c
CORE cores/sim_tiny25.c
CORE cores/sim_tiny44.c
CORE cores/sim_tiny45.c
CORE cores/sim_tiny84.c
CORE cores/sim_tiny85.c
CORE cores/sim_tinyx4.c
CORE cores/sim_tinyx5.c
AR obj-i686-redhat-linux/libsimavr.a
SHARED obj-i686-redhat-linux/libsimavr.so.1
ln -sf libsimavr.so.1 obj-i686-redhat-linux/libsimavr.so
CC sim/run_avr.c
LD obj-i686-redhat-linux/run_avr.elf
ln -sf obj-i686-redhat-linux/run_avr.elf run_avr
make[1]: Leaving directory `/home/iobst/gbsim/simavr'
make -C tests RELEASE=0
make[1]: Entering directory `/home/iobst/gbsim/tests'
AVR-CC atmega48_disabled_timer.c
171 0 0 171 ab atmega48_disabled_timer.axf
AVR-CC atmega88_coroutine.c
703 36 159 898 382 atmega88_coroutine.axf
AVR-CC atmega644_adc_test.c
2038 160 22 2220 8ac atmega644_adc_test.axf
AVR-CC atmega88_uart_echo.c
1872 68 88 2028 7ec atmega88_uart_echo.axf
AVR-CC atmega48_watchdog_test.c
371 82 6 459 1cb atmega48_watchdog_test.axf
AVR-CC atmega88_timer16.c
334 0 2 336 150 atmega88_timer16.axf
AVR-CC atmega48_enabled_timer.c
177 0 0 177 b1 atmega48_enabled_timer.axf
AVR-CC attiny85_crash_gdb.c
97 0 0 97 61 attiny85_crash_gdb.axf
AVR-CC atmega88_example.c
1746 118 6 1870 74e atmega88_example.axf
TST obj-i686-redhat-linux/test_atmega644_adc_test.tst
TST obj-i686-redhat-linux/test_atmega88_uart_echo.tst
TST obj-i686-redhat-linux/test_atmega48_watchdog_test.tst
TST obj-i686-redhat-linux/test_atmega88_timer16.tst
TST obj-i686-redhat-linux/test_atmega48_enabled_timer.tst
TST obj-i686-redhat-linux/test_atmega88_example.tst
TST obj-i686-redhat-linux/test_atmega48_disabled_timer.tst
make[1]: Leaving directory `/home/iobst/gbsim/tests'
make -C examples RELEASE=0
make[1]: Entering directory `/home/iobst/gbsim/examples'
for bi in board_timer_64led board_hd77480 board_simduino board_i2ctest board_ledramp; do make -C $bi; done
make[2]: Entering directory `/home/iobst/gbsim/examples/board_timer_64led'
AVR-CC atmega168_timer_64led.c
1860 20 53 1933 78d atmega168_timer_64led.axf
Package glu was not found in the pkg-config search path.
Perhaps you should add the directory containing `glu.pc'
to the PKG_CONFIG_PATH environment variable
No package 'glu' found
CC ../parts/button.c
CC ../parts/hc595.c
timer_64led.c:28:21: fatal error: GL/glut.h: No such file or directory
#include <GL/glut.h>
make[2]: *** [obj-i686-redhat-linux/timer_64led.o] Error 1
make[2]: Leaving directory `/home/iobst/gbsim/examples/board_timer_64led'
make[2]: Entering directory `/home/iobst/gbsim/examples/board_hd77480'
AVR-CC atmega48_charlcd.c
2073 14 5 2092 82c atmega48_charlcd.axf
CC ../parts/ac_input.c
CC ../parts/hd44780.c
../parts/hd44780_glut.c:28:21: fatal error: GL/glut.h: No such file or directory
make[2]: *** [obj-i686-redhat-linux/hd44780_glut.o] Error 1
make[2]: Leaving directory `/home/iobst/gbsim/examples/board_hd77480'
make[2]: Entering directory `/home/iobst/gbsim/examples/board_simduino'
AVR-CC atmega328p_dummy_blinky.c
333 66 6 405 195 atmega328p_dummy_blinky.axf
CC ../parts/uart_pty.c
simduino.c:33:21: fatal error: GL/glut.h: No such file or directory
make[2]: *** [obj-i686-redhat-linux/simduino.o] Error 1
rm atmega328p_dummy_blinky.axf
make[2]: Leaving directory `/home/iobst/gbsim/examples/board_simduino'
make[2]: Entering directory `/home/iobst/gbsim/examples/board_i2ctest'
AVR-CC atmega1280_i2ctest.c
941 16 12 969 3c9 atmega1280_i2ctest.axf
CC i2ctest.c
CC ../../examples/parts/i2c_eeprom.c
LD obj-i686-redhat-linux/i2ctest.elf
i2ctest done
make[2]: Leaving directory `/home/iobst/gbsim/examples/board_i2ctest'
make[2]: Entering directory `/home/iobst/gbsim/examples/board_ledramp'
AVR-CC atmega48_ledramp.c
1839 32 11 1882 75a atmega48_ledramp.axf
ledramp.c:28:21: fatal error: GL/glut.h: No such file or directory
make[2]: *** [obj-i686-redhat-linux/ledramp.o] Error 1
make[2]: Leaving directory `/home/iobst/gbsim/examples/board_ledramp'
make[1]: Leaving directory `/home/iobst/gbsim/examples'
make: *** [build-examples] Error 2
Skyrunner65
by 94k » Wed Aug 13, 2014 3:12 pm
Seems like you're missing libglu, try the devel version again.
94k
by Skyrunner65 » Wed Aug 13, 2014 3:31 pm
This is very annoying to me and you, I know, but:
make obj config
make[2]: Nothing to be done for `libsimavr'.
make[2]: `run_avr' is up to date.
make[1]: Nothing to be done for `all'.
i2ctest done
Skyrunner65
by 94k » Wed Aug 13, 2014 4:03 pm
It's still missing glu, I don't know which package exactly, since it worked for me without installing any additional glu package (meybe it was already installed though). Try your package manager and find something like glulib-devel.
94k
by Skyrunner65 » Wed Aug 13, 2014 6:05 pm
Now that I have it working, I think that we should put the emulator on the wiki.
I'll put instructions on how to run it on linux.
But to clean up the folder, what is needed to run the emulator?
Skyrunner65
Users browsing this forum: No registered users and 55 guests
