Fri Jul 31, 2015 10:51 am
deeph wrote:honolulu wrote:I think, I need to install sdk to launch a code to restaure my gamebuino now. It's the second time I have this problem.
I think you just have to hold the C button during a second or two while turning it on and it should reflash the loader.
If it is one of the more recent ones he has to hold it down more like 10 seconds or so.
Fri Jul 31, 2015 11:25 am
YES ! Thx guys, that work !
Sat Aug 01, 2015 5:31 pm
Fixed! Here it is:
- Attachments
- Dungeons_v11.zip
- (28.92 KiB) Downloaded 323 times
Sat Aug 01, 2015 5:38 pm
Yesss, now it's working! Looking quite awesome!
I find it confusing, though, how with the menus you *only* see the highlighted menu point and not the other things, too
Sat Aug 01, 2015 5:41 pm
Yes, that's how I designed it. However I cannot change it now or else the file will be to large. I had to take out some levels to make it less than
30 KB.
Sat Aug 01, 2015 5:42 pm
The limit is actually a bit higher, more like 31kb, not exactly sure where it is, it is 32KB minus the bootloader so it depends on the size of the bootloader.
Sat Aug 01, 2015 5:43 pm
To move around the menu, use the right and left buttons.
Yes, I noticed, I just meant that I find the way the UI is lay-outed quite confusing
Sat Aug 01, 2015 5:45 pm
If i make it above 30 KB it would crash.
Sat Aug 01, 2015 5:46 pm
Oh, I see.
You might be able to free up some space by storing levels on the sd-card
Powered by phpBB © phpBB Group.
phpBB Mobile / SEO by Artodia.
