Can't turn on
Re: Can't turn on
Postby Merlin » Mon Aug 24, 2015 1:58 pm
-- sorry for double post
Merlin
Re: Can't turn on
Postby Merlin » Mon Aug 24, 2015 2:09 pm
Same Problem here :D
It seems that the battery died.
USB does not deliver enoght power to keep the Gamebuino awake :/
While connected to USB the battery full LED in active.
And I can't compile + flash the loader. ( seems to work with the press C method from SDcard )
-Merlin
Merlin
Re: Can't turn on
Postby Klotzfisch » Thu Oct 22, 2015 8:17 pm
I have the same problem. Will try to solder a new battery tomorrow and report then.
Edit: Installed new battery, problem solved.
Klotzfisch
Re: Can't turn on
Postby Cerus33 » Tue May 31, 2016 6:10 pm
same problem for me.
[FR] je me permet de le dire en fr aussi au passage car c'est plus facile pour moi et ca evite peut etre de refaire un post sur le meme probleme. Donc si j'essais de l'allumer rien ne se passe. si je branche sur l'usb ca essais de s'allumer, j'ai parfois le logo, sinon j'ai les lumière qui clignotent, mais rien ne se passe.
J'ai cru comprendre qu'on demandais de teste le voltage de la battery mais la je sais pas....
Sinon pour info cela faisais quelques mois queje l'avais pas allumer, et je comptais teste des nouveaux jeux poste.
Si y'a une solution je suis preneur.
Cerus33
Re: Can't turn on
Postby rodot » Wed Jun 01, 2016 6:26 am
If the screens blinks when you try to turn your Gamebuino ON, it's because there isn't enough juice left in the battery to keep it ON. If after being plugged in for one hour it's still the case, then it means that the battery died, probably because it was left uncharged for too long. It's better to charge LiPo battery every now and then to avoid them to die (same applies for smartphones). You can replace the battery with any LiPo 3.7V of at least 200mAh (you can salvage some from RC copters or phones). Make sure it fits in the case, or make a custom case ;)
[FR] @Cerus33 Ces symptômes sont typiques d'une batterie vide, et si rien ne change même après une heure de charge alors c'est que la batterie est morte. C'est dû au fait que les batteries LiPo s'abîment lorsque l'on les laisse complètement vide, il vaut mieux les recharger un coup de temps en temps pour pas qu'elles ne se vident complètement à cause de la décharge résiduelle (comme les smartphones en fait). La batterie peut être remplacée par n'importe quelle LiPo 3.7V d'au moins 200mAh, il faut juste faire attention à ce qu'elle rentre dans le boitier, ou bien être prêt à fabriquer un boitier custom ;)
Re: Can't turn on
Postby Prozwolf » Wed Jun 01, 2016 6:32 am
Hey! Rodot! It's been too long, I see everything's nice and done...
Well, off to my question - I haven't turned on my gamebuino in two years. (Yes, it's one of the original indigogo ones) - I kinda forgot about it for two years. I'm experiencing the same problem as Tobi - so will LiPo batteries die over time if they're not used? Does this mean we'll have to replace the batteries every so often?
And yes, I've finally fished my gamebuino outta the closet. Still pristine... mostly.
Prozwolf
Re: Can't turn on
Postby rodot » Thu Jun 02, 2016 7:38 am
Hey!
Well, you should top up your battery every few months for it not to die, because of the residual discharge that will empty it. LiPo don't like to be over-discharged. It's something I working to solve on the next revision of Gamebuino.
Re: Can't turn on
Postby Cerus33 » Thu Jun 02, 2016 9:14 am
Juste pour savoir c'est pas trop dure à changer la batterie dessus? car visiblement je vais devoir la changer .....
Cerus33
Re: Can't turn on
Postby clement » Thu Jun 02, 2016 4:52 pm
Si tu sais utiliser un fer a souder c'est facile 2 point de soudure et c'est fait ;)
clement
Re: Can't turn on
Postby Cerus33 » Thu Jun 02, 2016 5:14 pm
clement wrote:Si tu sais utiliser un fer a souder c'est facile 2 point de soudure et c'est fait ;)
Mouai, j'ai jamais trop trop pratique le fer a souder :p je vais devoir voir avec un pote surement du coup
Cerus33
Previous
