by bobler900 » Sun Aug 03, 2014 1:05 pm
Ok, so when I pluged in the USB mircosd adapter it says to insert a disk so I do and then when I click on it again it says to insert a disk I have tried using a sd card adapter but that did not work either so if someone could please do and thanks
bobler900
by Matrix828 » Sun Aug 03, 2014 1:47 pm
Have you inserted the micro SD card into the adapter before plugging it into your computer?
Matrix828
by bobler900 » Sun Aug 03, 2014 6:40 pm
Matrix828 wrote:Have you inserted the micro SD card into the adapter before plugging it into your computer?
Yes I have tried that but again it failed ):
bobler900
by rodot » Sun Aug 03, 2014 8:22 pm
Did you try to move the micro SD card in the adapter? Be sure it's correctly aligned before you plug it in.
