[SOLVED] total newbie problems
Postby Montiey » Sat Jan 24, 2015 12:40 am
I'm not to new to programming or the arduino IDE, but I can't get this to work. It is supposed to count up, and thats about it.
num += 1;
gb.display.println(num);
When I run it on the gamebuino it just returns a stable "1", or sometimes a "0" if I try other methods of adding 1 to the variable every cycle.
Montiey
Re: total newbie problems
Postby GlueMen » Sat Jan 24, 2015 12:57 am
This should work:
num = 1 + num;
Here the variable num will be taken in the variable num to add 1 point
GlueMen
Postby Montiey » Sat Jan 24, 2015 1:44 am
This still doesn't work. I think the problem is with how 1 is added to the var, and not anything else because I set a var to 255, and it works fine.
int num = 255
Now, if I use
num = num + 3
it gives a 3, which leads me to believe that it goes once, but then does not loop for some reason.
Do you know if there is a sort of "while true do" loop or equivalent in c++?
Montiey
Postby Skyrunner65 » Sat Jan 24, 2015 1:54 am
Yeah, just like this:
volatile int num = 0  //says that num is a volatile integer (volatile meaning it is stored in RAM for fast access)
while(true) {
  num += 1;
Are you sure you have it in void loop?
Also, true can be changed to 1, since 1 also equals true.
Skyrunner65
Postby Montiey » Sat Jan 24, 2015 2:08 am
Here is all my code, but when I run it the popup I set that says "now counting" comes up, but thats all that changes and the tittle screen is still there, partially covered up behind the popup.
  //display the main menu:
  gb.titleScreen(F("super dumb app"));
  gb.popup(F("now counting"), 40);
    gb.display.println(F("Hello World!"));
    //declare a variable named count of type integer :
    int count;
    int test = 255;
    volatile int num = 0;  //says that num is a volatile fast acces RAM integer
    //get the number of frames rendered and assign it to the "count" variable
    count = gb.frameCount;
    //prints the variable "count"
    gb.display.println(count);
    //me stuffz
    gb.battery.show = false;
    gb.display.println("Jason Harriot 2015");
    while(true) {
      num += 1;
Montiey
Postby Myndale » Sat Jan 24, 2015 3:19 am
Actually your code is working fine, it's rendering the numbers but the back buffer isn't being sent to the LCD itself. One extra line in your inner loop will fix it:
while(true) {
      num += 1;
      gb.update();     // <---- add this
Postby rodot » Sat Jan 24, 2015 8:28 am
You should prefer the structure
while{
   if(gb.update()){ //returns true each time a frame is rendered
      //the code placed here will run once a frame
See gb.update
Because the way you wrote it it will run repeatedly in loop at high speed between each frame
So I changed your code for it to work properly. What I did is make two different screens with two loops. I added the fact that when you press "A" it will break out of the loop to continue on the next one. I also addec the ability to get back to the title screen to be able to get back to the loader.
  //first screen
  while(1){
      int count;
      int test = 255;
      //me stuffz
        break; //break out of the while loop when A is pressed
  //second screen
  while(true) {
      num += 1;
  //title screen to be able to get back to the game list
Postby Montiey » Sat Jan 24, 2015 2:22 pm
I kinda get it.
So the main loop runs any standalone code in it in loop fashion excluding other loops, but when there is a BREAK; it goes to the next loop down and when there is a BREAK; again it goes to the next one down it can find.
Looking at the code some more, it seems like there is an important reason that the gb.update is nested in a while loop. Can someone explain this further?
Montiey
Postby Skyrunner65 » Sat Jan 24, 2015 4:58 pm
If I put something like this:
void loop {
  while(1) {
    if (gb.update()) {
      gb.display.println("Potato!");
Then it would break off after printing that, then immediately go back in, since gb.update would be true again.
If I did this, however:
void loop {
  while(1) {
    if (gb.update()) {
      if (gb.button.pressed(BTN_C) {//If I Press C
        break;
        break;
gb.titlescreen("Hi There!")
It would add two breaks to its "counter", for a total of three (one to get out of "Pressed C" situation, another to get out of the gb.update() check, and the last to get out of the while(1) statement, to be able to go back to the titlescreen.
Skyrunner65
Postby Montiey » Sat Jan 24, 2015 10:06 pm
Great examples, thanks.
I've worked on this some more and I just can't see why this is giving me an error when I try to verify it.
  //first screen
  while(true){
      int count;
      count = gb.frameCount; //get the number of frames rendered and assign it to the "count" variable
      //me stuffz
  //second screen
  int num = 0;
  int offsetpause = 0;
  while(true){
        if(offsetpause = 1){
          offsetpause = 0;
        else{
          if(offsetpause = 0){
          offsetpause = 1;
        num += 1;
        num = 0;
        gb.popup(F("reset"), 5);
        break; //break out of the while loop when C is pressed
I can't see where my error was, but if someone can fix it I would be very glad. :)
Montiey
Next
Users browsing this forum: No registered users and 18 guests
