by STUDIOCRAFTapps » Mon Oct 10, 2016 6:03 pm
Hey!
I'm trying to include numbers in popup but i get a lot of error...
int Level = 3;
if(gb.buttons.pressed(BTN_A))
gb.popup(F("You beat the level " + Level), 20);
I don't know how F() works.
I alway get this error :
in expansion of macro 'F'
STUDIOCRAFTapps
by Duhjoker » Tue Oct 11, 2016 2:08 am
I can't "I" am going to say this,lol. But you should really check out the reference for the functions found here....
http://gamebuino.com/wiki/index.php?title=Referencewhere you are trying to add an argument for the level is actually for duration of the pop up. Instead it would be easier to write a popup for each level and then have it called once per level.
by STUDIOCRAFTapps » Tue Oct 11, 2016 11:50 am
DON'T LAUGH ABOUT MY ORTHOGRAPH... edit: And grammar
STUDIOCRAFTapps on Tue Oct 11, 2016 11:54 am, edited 1 time in total.
STUDIOCRAFTapps
by STUDIOCRAFTapps » Tue Oct 11, 2016 11:54 am
Duhjoker wrote:I can't "I" am going to say this,lol. But you should really check out the reference for the functions found here....
http://gamebuino.com/wiki/index.php?title=Referencewhere you are trying to add an argument for the level is actually for a duration of the pop-up. Instead, it would be easier to write a popup for each level and then have it called once per level.
Write a popup for each level? If we replace level by score, I need to add a lot of pop-ups.
STUDIOCRAFTapps
by rodot » Tue Oct 11, 2016 12:19 pm
Popups only accept stings stored in
PROGMEM so it doesn't eat up all the RAM. When you use F("your string"), it calls a macro that will make sure the string is stored in flash memory (aka PROGMEM) and *not* transferred to RAM when the function is called.
Pros : it saves RAM
Cons : content must be set at compilation time, it can't be dynamically changed at running time. So you can't use if for level or score, except if you create a separate string for each level as Duhjocker suggested.
Alternative solution : make your own popup function using the
Arduino String class. Takes more RAM, but it would be more versatile.
Here is a short example I just made you :
String myPopupText;
byte myPopupTimeLeft;
gb.titleScreen(F("Custom Popup"));
if(gb.update()){ //update everything
gb.display.println(F("Custom popups"));
gb.display.println(gb.frameCount);
myPopup(String("Frames = ") + gb.frameCount, 40);
myPopupUpdate();
void myPopup(String text, byte time){
myPopupText = text;
myPopupTimeLeft = time;
void myPopupUpdate(){
if (myPopupTimeLeft){
gb.display.fontSize = 1;
gb.display.setColor(WHITE);
gb.display.fillRoundRect(0,LCDHEIGHT-gb.display.fontHeight-3,84,gb.display.fontHeight+3,3);
gb.display.setColor(BLACK);
gb.display.drawRoundRect(0,LCDHEIGHT-gb.display.fontHeight-3,84,gb.display.fontHeight+3,3);
gb.display.cursorX = 4;
gb.display.cursorY = LCDHEIGHT-gb.display.fontHeight-1;
gb.display.print(myPopupText);
myPopupTimeLeft--;
by naed » Thu Oct 13, 2016 12:26 am
great post Rodot and something i really needed to look at to for my current Gamebuino project
naed
