Switch to full style
Post a reply
[Help]Multidimensional arrays. Read it if you need help!
Wed Apr 29, 2015 2:27 pm
In my snake game I'm making I use multidimensional arrays with a set size of the biggest sprite put in the array. It works for now but that's not exactly what I want. I Either would like to use a multidimensional array with different item lenghts per collum or just make a array unto wich I put another with the right lenght per sprite (Wich should work because I remember doing something similar in C++ once). But the thing is the ways I wrote don't work for some reason. Could you help?
Re: Multidimensional arrays
Wed Apr 29, 2015 2:34 pm
Or better yet is there a way so see how much elements are there int the array? For example I make a 6 item array, but I only use 2 of the six blocks. How can the program find that out?
Thu Apr 30, 2015 6:44 pm
for multidimentinal array you can use a array of pointer :
Code:
const byte background[] PROGMEM = {88,48,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x0,0x0,0x8,0x0,0x0,0x0,0x0,0x0,0x7F,0xFE,0xDA,0x40,0xFF,0xD0,0x0,0x0,0x0,0x70,0x0,0x0,0xFE,0xA,0xA0,0xFF,0xA0,0x0,0x0,0x0,0xF8,0x0,0x0,0xE,0xF9,0x20,0xFF,0x41,0xFF,0xF0,0x1,0x6C,0x0,0x0,0x1,0xF8,0x0,0xFE,0x82,0x0,0x0,0x1,0x4,0x3F,0x80,0x0,0x79,0x0,0xFD,0x4,0x0,0x0,0x1,0x7C,0xF,0xFF,0x0,0x3A,0x80,0xFA,0x8,0x0,0x0,0x0,0xF8,0x0,0x7F,0xF0,0x3A,0x80,0xF4,0x10,0xFF,0xFC,0x0,0x70,0x0,0x0,0xFC,0x18,0x0,0xE8,0x21,0xFF,0xFE,0x0,0x0,0x0,0x0,0xE,0x19,0x0,0xD0,0x1,0xF0,0x0,0x0,0x0,0x0,0x0,0x6,0x1A,0x80,0xA0,0x1,0xC0,0x0,0x0,0x0,0x0,0x0,0x6,0x19,0x0,0x40,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x3,0x8,0x0,0x80,0x0,0x1,0xF0,0x0,0x0,0x0,0x0,0x3,0xB,0x80,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x3,0x8,0x80,0x0,0x1,0xF0,0x0,0x0,0x70,0x0,0x1C,0x1,0x8,0x80,0x0,0x0,0x0,0x0,0x0,0xF8,0x0,0x3E,0x1,0x8,0x0,0x0,0x0,0x1,0xF0,0x1,0x14,0x0,0x55,0x0,0xB,0x80,0x0,0x0,0x0,0x0,0x1,0x54,0x0,0x55,0x0,0xA,0x80,0x0,0x1,0xF0,0x0,0x1,0x44,0x0,0x41,0x0,0xA,0x0,0x0,0x0,0x0,0x0,0x0,0xF8,0x0,0x3E,0x0,0x8,0x0,0x0,0x0,0x1,0xF0,0x0,0x70,0x0,0x1C,0x0,0xA,0x20,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x8,0x0,0x0,0x1,0xF0,0x0,0x0,0x0,0x0,0x0,0x0,0x8,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x8,0x0,0x0,0x0,0x1,0xF0,0x0,0x0,0x0,0x0,0x0,0x8,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x8,0x0,0x0,0x1,0xF0,0x0,0x0,0x0,0x0,0x0,0x0,0x8,0x0,0x0,0x0,0x0,0x0,0x0,0x70,0x0,0x0,0x0,0x8,0x0,0x80,0x0,0x1,0xF0,0x0,0xF8,0x0,0x0,0x0,0x8,0x0,0x40,0x0,0x0,0x0,0x1,0x6C,0x0,0x0,0x0,0x8,0x0,0xA0,0x1,0xC0,0x0,0x1,0x4,0x0,0x3E,0x18,0x8,0x0,0xD0,0x1,0xF0,0x0,0x1,0x7C,0x1,0xD5,0xC,0x8,0x0,0xE8,0x21,0xFF,0xFE,0x0,0xF8,0xF,0xD5,0xC,0x8,0x0,0xF4,0x10,0xFF,0xFC,0x0,0x70,0x7,0xC1,0xE,0x8,0x0,0xFA,0x8,0x0,0x0,0x0,0x0,0x3,0xFF,0xE,0x8,0x0,0xFD,0x4,0x0,0x0,0x0,0x0,0x0,0x0,0xE,0x18,0x0,0xFE,0x82,0x0,0x0,0x0,0x0,0x20,0x0,0xE,0x18,0x0,0xFF,0x41,0xFF,0xF0,0x0,0x0,0x30,0x0,0x1C,0x18,0x0,0xFF,0xA0,0x0,0x0,0x0,0x0,0x3C,0x0,0xF8,0x18,0x0,0xFF,0xD0,0x0,0x0,0x0,0x0,0x3F,0xFF,0xF0,0x38,0x0,0x0,0x8,0x0,0x0,0x0,0x0,0x3F,0xFF,0x0,0x38,0x0,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x80,0x0,0x78,0x0,0xFF,0xF8,0x0,0x0,0x0,0x0,0x0,0x0,0x1,0xF8,0x0,0xFF,0xF8,0x0,0x0,0x0,0x0,0x0,0x0,0xF,0xF8,0x0,0xFF,0xF8,0x0,0x0,0x0,0x0,0x0,0x0,0xFF,0xF8,0x0,0xFF,0xF8,0x0,0x0,0x0,0x0,0x0,0x7F,0xFF,0xF8,0x0,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x0,};
const byte ball[] PROGMEM = {8,4,0x60,0xF0,0xD0,0x60,};
const byte flipperBas[] PROGMEM = {8,9,0x60,0x60,0xE0,0xE0,0xE0,0xC0,0xC0,0x80,0x80,};
const byte flipperHaut[] PROGMEM = {8,7,0x40,0xF0,0x38,0x38,0x1E,0xE,0x3,};
#define SIZE_ARRAY 3
byte const * multiDimArray[SIZE_ARRAY]={
  background,
  ball,
  flipperBas
for(int i=0;i<SIZE_ARRAY;i++)
  //do somthing with the pointer
Thu Apr 30, 2015 7:11 pm
You see people? This is why others (myself included) need to learn pointers. Thanks for the help :D. I didn't want go on with the menu until I got a answer so that I'd wouldn't have to rewrite alot of stuff. I already had a solution but not one I was happy with so thanks yet again :D
Re: [Help]Multidimensional arrays. Read it if you need help!
Sun May 03, 2015 11:18 am
Now that I'm usin a multidimensional pointer array I'm having problems doing this
Code:
for(int r = 0, y = 0, x = 0; r < 6; r++)
         x = (sizeof(gameMenu[r]) - 2) / 7 * 8;
         x = LCDWIDTH - x;
         gb.display.drawBitmap(x, y, gameMenu[r]);
         y = y + 8;
It calculates where the menu icons need to be and draws them. It worked fine before
Sun May 03, 2015 3:46 pm
Please add the declarion of the array.
thx.
Sun May 03, 2015 3:57 pm
what do you mean? It was declared, I think...
This is how I did it. Just how you showed it
Code:
byte const * gameMenu[] =
 single,
 multi,
 classic,
 settings,
 credits,
 exitGame
before that I declred all the sprites
Code:
const byte single[] PROGMEM =
//sprite
// so on and so on
Sun May 03, 2015 4:06 pm
The problem is that
Code:
sizeof(gameMenu[r])
allways returns a value of zero now that I've swithced to a multidimensional pointer array
Sun May 03, 2015 4:22 pm
Sorry my english is bad and my word can be misunderstand :o
I would like , see all the code.
I have tested with a simple example :
Code:
    background,
    ball,
    flipperBas
void loop()
 if(gb.update())
      gb.display.drawBitmap(random(0,42),random(0,24), multiDimArray[i]);
I think , you need for positioning your image the width and the height
it's the two first number in the image
I test this :
Code:
       int8_t width = pgm_read_byte(multiDimArray[i]);
       int8_t height = pgm_read_byte((multiDimArray[i] + 1));
      gb.display.drawBitmap(width/2,height/2, multiDimArray[i]);
it's work
I hope help you :)
Sun May 03, 2015 4:30 pm
Thanks. I've never heard of the pgm_read_byte function. That's probably what I needed. I'll try it out a bit later then :D
Post a reply
