by Sandman » Tue May 05, 2015 7:14 pm
Hello, i have built a gamebuino and my sd card slod havent arrived yet, so i decided to upload the hex file with Xloader. When i turn on the gamebuino it shows the logo and the low battery screen. I have tried to change the settings but with no result. Thanks for your help
Sandman
by fazo96 » Sun Jul 12, 2015 8:49 pm
I'm not an hardware expert but it's probably because your battery wiring is different from the Gamebuino's. What you can do is recompile the game/program you want to run but using a modified library with the battery check disabled. If you look at the source code of the Gamebuino library (here:
https://github.com/Rodot/Gamebuino/blob/master/libraries/Gamebuino/settings.c) you can see that you can disable battery monitoring at line 38:
#define ENABLE_BATTERY 1 //disable battery monitoring
If this doesn't work then I'm not sure what you could do, except further removing battery checks from the library
fazo96
by rodot » Sun Jul 12, 2015 9:12 pm
No need to recompile the games, simply upload settings.hex and set the critical battery level to 0. It should do the trick
Users browsing this forum: No registered users and 79 guests
