[Solved] Lunar run SD Code
Postby clement » Sun May 10, 2015 7:43 am
I would like to use the Myndale Code of Lunar run for a new game.
But I don't understand how this work.
First Myndale Use the persistence :
And he load the map ".DAT"
PFFS.lseek_file(screen_num*(LCDWIDTH*LCDHEIGHT/8));
    uint8_t * buffer = gb.display.getBuffer();
    for (int row=0; row<LCDHEIGHT/8; row++, buffer+=LCDWIDTH)
      PFFS.read_file((char *)buffer, LCDWIDTH, &bytes_read);
Finally he draw the ship :
gb.display.setColor(INVERT);
  if (grayscale_frame)
    drawBitmap(dst_x, dst_y, dst_w, dst_h, src_x, src_y, image1);
  else
    drawBitmap(dst_x, dst_y, dst_w, dst_h, src_x, src_y, image2);
All work fine !
When I do the same thing in my game the world is correctly draw, but the Player are persisted in the screen.
the code for load map is same as the Myndale Code
I change the code for draw Player :
    gb.display.drawBitmap((player.x % LCDWIDTH) - 4,(player.y % LCDHEIGHT) - 5, player.sprites[player.currentState].sprite1); //Sprite
/* another test */
/* another test */
    gb.display.setColor(INVERT,INVERT);
    if(gb.frameCount%2 == 0)//grey scale frame
    else {
      gb.display.drawBitmap((player.x % LCDWIDTH) - 4,(player.y % LCDHEIGHT) - 5, player.sprites[player.currentState].sprite2); //inverse sprite (black are white and white are black)
/* and with draw Myndale's bitmap */
      drawBitmap((player.x % LCDWIDTH) - 4,(player.y % LCDHEIGHT) - 5,8,11,0,0, player.sprites[player.currentState].sprite1);
    else {
      drawBitmap((player.x % LCDWIDTH) - 4,(player.y % LCDHEIGHT) - 5,8,11,0,0, player.sprites[player.currentState].sprite2);
Thx for your help :)
clement
Re: Lunar run SD Code
Postby Myndale » Tue May 19, 2015 6:02 am
I'd have to see a working sample of your code but I'll try to explain how the LunarRun code works. At the moment there isn't enough free RAM to store the entire screen, even in compressed format. What I do instead is load the level in and draw the ship in its current position using INVERT. Then, once per frame I draw the ship in its old position using INVERT to erase it, update the ship position and then draw it with INVERT again.
I haven't looked closely at your code but if you're seeing your player persisting then it probably means either 1) you haven't drawn it with INVERT immediately after the erase, 2) you're not doing it twice in your render look, or 3) you're not updating the ship position in between the two. Remember the purpose of the first draw is to erase the ship from the previous frame, so make sure you draw it in exactly the same position that you drew it the second time in the frame before.
Postby clement » Tue May 19, 2015 6:51 am
Thx Myndale,
I draw my sprite with invert but I do it once per frame.
Thx a lot !
clement
Re: [Solved] Lunar run SD Code
Postby jonnection » Mon May 25, 2015 1:04 pm
Myndale wrote:I'd have to see a working sample of your code but I'll try to explain how the LunarRun code works. At the moment there isn't enough free RAM to store the entire screen, even in compressed format. What I do instead is load the level in and draw the ship in its current position using INVERT. Then, once per frame I draw the ship in its old position using INVERT to erase it, update the ship position and then draw it with INVERT again.
That is, however, not the only way to do it. You could simply draw the screen once per each refresh directly from the SD card.
Here is 20 frames per second directly from SD card with PetitFATFS with 2 x 128 byte buffer.
Users browsing this forum: No registered users and 76 guests
