Duhjoker wrote:For grey tiles lik sand you would probably have to make two tilemaps. One with the black sprites then one with oonly the floor tiles.
but how would i place them, as each tileset place only allows for placement of one sprite, not two... unless i'd need to overlay the two tilemaps??
i'm just going to take a look at your boundary recognition you posted, although i'm already able to set boundaries for the camera
if(camerax >=0) camerax = 0;
thats the easy part, the problem i have is that when the camera reaches the boundary and stops, so does the player - he doesn't continue walking to the edge of the screen like in Summoner123's example.... i'm yet to figure that part out
EDIT
got it to work
const byte tilemap[] PROGMEM = {17,11,
8,8,
2, 2, 2, 2, 2, 2, 2,19, 8, 8, 3,18,18,18,18,18, 2,
2, 2, 2, 2, 2, 2, 2,19, 8, 8,27,27,27,27,27,27,20,
2, 2, 2, 2, 2, 2, 2,19, 8, 8,26,26,26,26,26,26,20,
2, 2, 2, 2, 2, 2,18, 4, 8, 8,25,26,26,26,26,26,20,
2, 2, 2, 2, 2, 4, 8, 8, 8, 8, 8,26,26,26,26,26,20,
2, 2, 2, 2, 4, 8, 8, 8, 8, 8, 8,26,26,26,26,26,20, /////////112x64 pix res
18,18,18, 4, 8, 8, 8, 8, 8, 8, 8, 8,25,25,25,25, 3,
8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8,
21,21, 6, 8, 8, 8,22,23,24, 8, 8, 8, 8, 8, 5,21,21,
2, 2,19, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8,20, 2, 2,
2, 2, 2,21,21,21,21,21,21,21,21,21,21,21, 2, 2, 2,};
const byte bush[] PROGMEM = {B00101100,B01010010,B10001001,B01000010,B10010001,B01001010,B00100100,B01111110,};
const byte port_noir[] PROGMEM = {B11111111,B11111111,B11111111,B11111111,B11111111,B11111111,B11111111,B11111111,};
const byte rock_terrain_master[] PROGMEM = {B00000010,B00010000,B01000000,B00000010,B00010000,B00001000,B01000001,B00000100,};
const byte rock_valley_ne[] PROGMEM = {B10100000,B11001001,B01110000,B00001100,B00000101,B00000100,B00000110,B00000011,};
const byte rock_valley_nw[] PROGMEM = {B00000101,B10010011,B00001110,B00110000,B10100000,B00100000,B01100000,B11000000,};
const byte rock_valley_se[] PROGMEM = {B00000011,B00000110,B00000100,B00000101,B00001100,B01110000,B11001001,B10100000,};
const byte rock_valley_sw[] PROGMEM = {B11000000,B01100000,B00100000,B10100000,B00110000,B00001110,B10010011,B00000101,};
const byte turtle_rock[] PROGMEM = {B01101100,B10110010,B11010001,B01010101,B01010010,B10011001,B10000001,B11111110,};
const byte void_tile[] PROGMEM = {B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,};
const byte water_left_bottom[] PROGMEM = {B10001111,B10000000,B11110000,B10000000,B10001111,B10000000,B11110000,B11111111,};
const byte water_left_middle[] PROGMEM = {B10001111,B10000000,B11110000,B10000000,B10001111,B10000000,B11110000,B10000000,};
const byte water_left_top[] PROGMEM = {B11111111,B10000000,B11110000,B10001111,B10000000,B10000000,B11110000,B10000000,};
const byte water_right_bottom[] PROGMEM = {B1110001,B00000001,B0000111,B00000001,B11110001,B00000001,B00001111,B11111111,};
const byte water_right_middle[] PROGMEM = {B11110001,B00000001,B00001111,B00000001,B11110001,B00000001,B00001111,B00000001,};
const byte water_right_top[] PROGMEM = {B11111111,B00000001,B00001111,B00000001,B11110001,B00000001,B00001111,B00000001,};
const byte water_middle_bottom[] PROGMEM = {B11110000,B00000000,B00001111,B00000000,B11110000,B00000000,B00001111,B11111111,};
const byte water_middle_middle[] PROGMEM = {B11110000,B00000000,B00001111,B00000000,B11110000,B00000000,B00001111,B00000000,};
const byte water_middle_top[] PROGMEM = {B11111111,B00000000,B11110000,B00000000,B00001111,B00000000,B11110000,B00000000,};
const byte rock_s[] PROGMEM = {B00010010,B00000000,B01001000,B00000100,B00100001,B10001100,B01110010,B10000001,};
const byte rock_e[] PROGMEM = {B00000101,B00100010,B00001010,B10000010,B00100100,B00010100,B10000010,B00001001,};
const byte rock_n[] PROGMEM = {B10000001,B01110010,B10001100,B00100001,B00000100,B01001000,B00000000,B00010010,};
const byte rock_w[] PROGMEM = {B10100000,B01000100,B01010000,B01000001,B00100100,B00101000,B01000001,B10010000,};
const byte bush_left[] PROGMEM = {B00111011,B01000100,B10100000,B10010100,B01000010,B10000000,B10001000,B01110111,};
const byte bush_middle[] PROGMEM = {B10111101,B01000010,B00001000,B10000100,B00010000,B00100001,B10001000,B01110111,};
const byte bush_right[] PROGMEM = {B11011100,B00100010,B00000101,B00101001,B01000010,B00000001,B00010001,B11101110,};
const byte tree_base[] PROGMEM = {B01010100,B01000100,B10100010,B10001010,B10000010,B01101100,B00101000,B00101000,};
const byte tree_repeat[] PROGMEM = {B01010100,B01000100,B10000010,B10010010,B10101010,B01101100,B00101000,B01000100,};
const byte tree_top[] PROGMEM = {B00000000,B00000000,B00000000,B00010000,B00101000,B00101000,B00101000,B01000100,};
const byte *spritesheet[] = {bush, //0
port_noir, //1
rock_terrain_master, //2
rock_valley_ne, //3
rock_valley_nw, //4
rock_valley_se, //5
rock_valley_sw, //6
turtle_rock, //7
void_tile, //8
water_left_bottom, //9
water_left_middle, //10
water_left_top, //11
water_right_bottom, //12
water_right_middle, //13
water_right_top, //14
water_middle_bottom, //15
water_middle_middle, //16
water_middle_top, //17
rock_s, //18
rock_e, //19
rock_w, //20
rock_n, //21
bush_left, //22
bush_middle, //23
bush_right, //24
tree_base, //25
tree_repeat, //26
tree_top}; //27
const byte backblack[] PROGMEM = {8,8,0x7E,0x42,0x42,0x3C,0x7E,0x3C,0x3C,0x24,};
const byte backgrey[] PROGMEM = {8,8,0x1,0x1,0x1,0xC1,0x81,0xC0,0x40,0x0,};
const byte frontblack[] PROGMEM = {8,8,0x7E,0x66,0x42,0x38,0x78,0x38,0x3C,0x24,};
const byte frontgrey[] PROGMEM = {8,8,0x80,0x80,0x80,0x87,0x87,0x7,0x2,0x0,};
const byte leftblack[] PROGMEM = {8,8,0x3E,0x32,0x22,0x1C,0x1C,0x1C,0x1C,0x14,};
const byte leftgrey[] PROGMEM = {8,8,0x0,0x0,0x0,0x60,0x60,0x60,0x40,0x0,};
const byte rightblack[] PROGMEM = {8,8,0x7C,0x4C,0x44,0x38,0x3C,0x38,0x38,0x28,};
const byte rightgrey[] PROGMEM = {8,8,0x2,0x2,0x2,0x2,0x2,0x0,0x0,0x0,};
int player_x = 70; //cant get these to center
int player_y = 40; //cant get these to center
int player_direction = 0;
int x,y; ///if 0 player spite will not move, -50,50 no tilemap
//////CAMERA//////
int camerax = -20 ;
int cameray = -20 ;
int xmax = -68;
gb.titleScreen(F("test"));
gb.setFrameRate(62); ////////for sprite
/////////PLAYER_MOVEMENT\\\\\\\\\
if (gb.buttons.repeat(BTN_RIGHT,1));{x--;}
if (gb.buttons.repeat(BTN_LEFT,1));{x++;}
if (gb.buttons.repeat(BTN_DOWN,1));{y--;}
if (gb.buttons.repeat(BTN_UP,1));{y++;}
if(player_x > 59 && camerax < 0 && camerax > -52){player_x = 59;camerax--;}
//value 59 equals player position on right when camera will start to follow
//value 0 and -52 equals camera boundary positions
else if(player_x < 15 && camerax < 0 && camerax > -52){player_x = 15;camerax++;}
//value 15 equals player position on left when camera will start to follow
else if(player_x > 59 && camerax <= 0 && camerax >= -52)camerax--;
else if(player_x < 15 && camerax <= 0 && camerax >= -52)camerax++;
if(player_y > 28 && cameray < 0 && cameray > -40){player_y = 28;cameray--;}
//value 28 equals player position on right when camera will start to follow
//value 0 and -40 equals camera boundary positions
else if(player_y < 15 && cameray < 0 && cameray > -40){player_y = 15;cameray++;}
else if(player_y > 28 && cameray <= 0 && cameray >= -40)cameray--;
else if(player_y < 15 && cameray <= 0 && cameray >= -40)cameray++;
if(camerax > 0)camerax= 0;
else if(camerax < -52) camerax = -52;
if(cameray > 0)cameray= 0;
else if(cameray < -40) cameray = -40;
gb.display.drawTilemap(camerax,cameray,tilemap,spritesheet); // draw the tilemap
// gb.display.cursorY = 12; gb.display.println( player_x );gb.display.println( player_y );
gb.display.setColor(BLACK);{
gb.display.drawBitmap(player_x,player_y,backblack);
gb.display.setColor(GRAY);{
gb.display.drawBitmap(player_x,player_y,backgrey);
player_direction = 1;
player_y = player_y - 1;
if(checkcolision())player_y++; // ADD by Summoner123 - If have colision on the new position regreat one Pixel
if(player_y <= 0){
player_y = 0;}
gb.display.drawBitmap(player_x,player_y,frontblack);
gb.display.drawBitmap(player_x,player_y,frontgrey);
player_direction = 2;
player_y = player_y + 1;
if(checkcolision())player_y--; // ADD by Summoner123 - If have colision on the new position regreat one Pixel
if(player_y >= 40){
player_y = 40;}
gb.display.drawBitmap(player_x,player_y,rightblack);
gb.display.drawBitmap(player_x,player_y,rightgrey);
player_direction = 3;
player_x = player_x + 1;
if(checkcolision())player_x--; // ADD by Summoner123 - If have colision on the new position regreat one Pixel
if(player_x >= 77){
player_x = 77;}
gb.display.drawBitmap(player_x,player_y,leftblack);
gb.display.drawBitmap(player_x,player_y,leftgrey);
player_direction = 4;
player_x = player_x - 1;
if(checkcolision())player_x++; // ADD by Summoner123 - If have colision on the new position regreat one Pixel
if(player_x <= -2){
player_x = -2;}
if (player_direction == 1){
else { gb.display.setColor(BLACK);{
bool checkcolision() // Transformed it into a function
uint16_t i;
if(gb.collideRectRect(player_x,player_y,8,8,gb.display.solid[i].x,gb.display.solid[i].y,8,8))///changed player_x,y back to 8
// if(gb.display.solid[i].spritecol == void_tile); //Do nothing because it's floor - This line not needed
if(gb.display.solid[i].spritecol == bush) return true;
else if(gb.display.solid[i].spritecol == port_noir) return true;
else if(gb.display.solid[i].spritecol == rock_terrain_master) {gb.popup(F(" ""Rock"" "),1); return true;} //Return True if character have touched the wall
else if(gb.display.solid[i].spritecol == rock_valley_ne) return true;
else if(gb.display.solid[i].spritecol == rock_valley_nw) return true;
else if(gb.display.solid[i].spritecol == rock_valley_se) return true;
else if(gb.display.solid[i].spritecol == rock_valley_sw) return true;
else if(gb.display.solid[i].spritecol == turtle_rock) return true;
else if(gb.display.solid[i].spritecol == water_left_bottom) return true;
else if(gb.display.solid[i].spritecol == water_left_middle) return true;
else if(gb.display.solid[i].spritecol == water_left_top) return true;
else if(gb.display.solid[i].spritecol == water_right_bottom) return true;
else if(gb.display.solid[i].spritecol == water_right_middle) return true;
else if(gb.display.solid[i].spritecol == water_right_top) return true;
else if(gb.display.solid[i].spritecol == water_middle_bottom) return true;
else if(gb.display.solid[i].spritecol == water_middle_middle) return true;
else if(gb.display.solid[i].spritecol == water_middle_top) return true;
else if(gb.display.solid[i].spritecol == rock_n) return true;
else if(gb.display.solid[i].spritecol == rock_e) return true;
else if(gb.display.solid[i].spritecol == rock_s) return true;
else if(gb.display.solid[i].spritecol == rock_w) return true;
else if(gb.display.solid[i].spritecol == bush_left) {gb.popup(F(" ""A bush!!"" "),1); return true;}
else if(gb.display.solid[i].spritecol == bush_middle) {gb.popup(F(" ""A bush!!"" "),1); return true;}
else if(gb.display.solid[i].spritecol == bush_right) {gb.popup(F(" ""A bush!!"" "),1); return true;}
else if(gb.display.solid[i].spritecol == tree_base) return true;
else if(gb.display.solid[i].spritecol == tree_repeat) return true;
else if(gb.display.solid[i].spritecol == tree_top) return true;
return false; // Return false if don't touch anything
I changed the sprites in this one as i was playing around ( and also the tilemap size) but you should be able to just take this code and copy it into your project if you need to - i've commented it the best i can to explain
