Page 6 of 6
Re: TilemapRamino example
PostPosted: Sun May 28, 2017 3:01 am
by awesome101
Copy and paste this into whichever file all your drawTilemap functions are:
void Grafx_esp::drawTilemap(const uint8_t **spritesheet)
for(unsigned int y = 0; y < 15; y++) {
for(unsigned int x = 0; x < 20; x++) {
int tile = pgm_read_byte(tilemap_black + (x + y * 20));
drawBitmap(x * 16, y * 16, spritesheet[tile], 16, 16, BLACK);
Then comment out all the other drawTilemap functions and call the function above like drawTilemap(spritesheet1);
PostPosted: Sun May 28, 2017 3:13 am
by awesome101
Don't add any w or h just do what I said in the previous post
by awesome101
and make sure to type it in exactly the same
PostPosted: Sun May 28, 2017 3:18 am
by Duhjoker
almost there......
Arduino: 1.8.1 (Windows 10), TD: 1.36, Board: "ESP32 Dev Module, 80MHz, 921600, None"
WARNING: library SPI claims to run on [esp32] architecture(s) and may be incompatible with your current board which runs on [Esp32] architecture(s).
C:\Users\chuck\OneDrive\Documents\Arduino\libraries\GameRIot_ESP\Grafx_esp.cpp:1189:1: error: expected initializer before 'for'
C:\Users\chuck\OneDrive\Documents\Arduino\libraries\GameRIot_ESP\Grafx_esp.cpp:1189:25: error: 'y' does not name a type
C:\Users\chuck\OneDrive\Documents\Arduino\libraries\GameRIot_ESP\Grafx_esp.cpp:1189:33: error: 'y' does not name a type
exit status 1
Error compiling for board ESP32 Dev Module.
Thank you by the way!!!! I appreciate your time. Sorry I'm so slow
PostPosted: Sun May 28, 2017 3:38 am
by awesome101
Can you post your code so I can take a look
PostPosted: Sun May 28, 2017 3:49 am
by Duhjoker
here is the sketch
#include <Grafx_esp.h>
#include "SPI.h"
#define TFT_SCK 18
#define TFT_MISO 19
#define TFT_MOSI 23
#define TFT_DC 5
#define TFT_CS 22
#define TFT_RST 17
Grafx_esp tft = Grafx_esp(TFT_CS, TFT_DC, TFT_RST, TFT_MOSI, TFT_SCK, TFT_MISO);
//Adafruit_GFX_Button button;
uint8_t use_clip_rect = 0;
uint8_t use_set_origin = 0;
uint8_t use_fb = 0;
int player_x = 160;
 int player_y = 110;
 int player_direction = 2;
int x=-0,y=0;
//////////Paul_Atreades
//////////paul front
const byte paul_frontblack[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x02,0x40,0x02,0x30,0x0c,0x38,0x1c,0x4c,0x32,0x4f,0xf2,0x39,0x9c,0x16,0x68,0x11,0x88,0x08,0x10,0x0e,0x70};
const byte paul_frontblue[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x40,0x02,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x06,0x00,0x01,0x80,0x06,0x60,0x06,0x60,0x00,0x00};
const byte paul_frontbrown[] PROGMEM = {16,16,
0x0e,0x70,0x1b,0xd8,0x16,0x68,0x19,0x98,0x20,0x04,0x16,0x68,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
const byte paul_frontgreen[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
const byte paul_frontgrey[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x10,0x08,0x10,0x00,0x00,0x00,0x00};
const byte paul_frontpink[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x06,0x60,0x0f,0xf0,0x29,0x94,0x3d,0xbc,0x0d,0xb0,0x07,0xe0,0x33,0xcc,0x30,0x0c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
const byte paul_frontred[] PROGMEM = {16,16,
0x01,0x80,0x04,0x20,0x09,0x90,0x20,0x04,0x10,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0,0x00,0x00,0x00,0x00};
////////paul_front_walk_1
const byte paul_frontw1black[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x02,0x40,0x02,0x30,0x0e,0x38,0x1a,0x24,0x3c,0x27,0x98,0x19,0x68,0x0e,0x88,0x0e,0x10,0x00,0x10,0x00,0x70};
const byte paul_frontw1blue[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x40,0x02,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x06,0x80,0x00,0x60,0x00,0x60,0x00,0x60,0x00,0x00};
const byte paul_frontw1brown[] PROGMEM = {16,16,
const byte paul_frontw1green[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
const byte paul_frontw1grey[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x00,0x10,0x00,0x00,0x00,0x00,0x00,0x00};
const byte paul_frontw1pink[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x06,0x60,0x0f,0xf0,0x29,0x94,0x3d,0xbc,0x0d,0xb0,0x07,0xe4,0x1b,0xc0,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
const byte paul_frontw1red[] PROGMEM = {16,16,
0x01,0x80,0x04,0x20,0x09,0x90,0x20,0x04,0x10,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
////////paul_front_walk_2
const byte paul_frontw2black[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x02,0x40,0x02,0x70,0x0c,0x58,0x1c,0x3c,0x24,0x19,0xe4,0x16,0x98,0x11,0x70,0x08,0x70,0x08,0x00,0x0e,0x00};
const byte paul_frontw2blue[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x40,0x02,0x40,0x00,0x00,0x00,0x00,0x06,0x00,0x01,0x60,0x06,0x00,0x06,0x00,0x06,0x00,0x00,0x00};
const byte paul_frontw2brown[] PROGMEM = {16,16,
const byte paul_frontw2green[] PROGMEM = {16,16,
const byte paul_frontw2grey[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
const byte paul_frontw2pink[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x06,0x60,0x0f,0xf0,0x29,0x94,0x3d,0xbc,0x0d,0xb0,0x27,0xe0,0x03,0xd8,0x00,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
const byte paul_frontw2red[] PROGMEM = {16,16,
////////paul left
 const byte paul_leftblack[] PROGMEM = {16,16,
0x00,0x00,0x00,0x0,0x00,0x00,0x00,0x00,0x10,0x00,0x14,0x00,0x10,0x00,0x10,0x00,0x08,0x60,0x07,0xe0,0x00,0x20,0x03,0x20,0x04,0xe0,0x04,0x20,0x01,0xc0,0x03,0xc0};
const byte paul_leftblue[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x00,0x00};
const byte paul_leftbrown[] PROGMEM = {16,16,
0x0e,0xd8,0x0d,0xa8,0x1b,0x74,0x3e,0xec,0x01,0xd8,0x00,0xb4,0x00,0x88,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
const byte paul_leftgreen[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
const byte paul_leftgrey[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x01,0xc0,0x00,0x00,0x00,0x00};
const byte paul_leftpink[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0e,0x00,0x0b,0x00,0x0b,0x60,0x0f,0xe0,0x07,0x80,0x00,0x00,0x00,0xc0,0x00,0xc0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
const byte paul_leftred[] PROGMEM = {16,16,
0x01,0x20,0x12,0x54,0x24,0x88,0x01,0x10,0x00,0x24,0x00,0x48,0x00,0x10,0x00,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
///////paul_left_walk
const byte paul_leftwblack[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x00,0x14,0x00,0x10,0x00,0x10,0x00,0x08,0x60,0x04,0xe0,0x1f,0x98,0x24,0x94,0x13,0xe4,0x12,0x44,0x02,0x24,0x0e,0x18};
const byte paul_leftwblue[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x08,0x08,0x18,0x0c,0x38,0x0c,0x18,0x00,0x00};
const byte paul_leftwbrown[] PROGMEM = {16,16,
0x0e,0xe8,0x0d,0xd8,0x1b,0xb4,0x3f,0x6c,0x01,0xd8,0x00,0xb4,0x00,0x88,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
const byte paul_leftwgreen[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
const byte paul_leftwgrey[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x00,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
const byte paul_leftwpink[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0e,0x00,0x0b,0x00,0x0b,0x60,0x0f,0xe0,0x07,0x80,0x00,0x00,0x00,0x60,0x00,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
const byte paul_leftwred[] PROGMEM = {16,16,
0x01,0x10,0x12,0x24,0x24,0x48,0x00,0x90,0x00,0x24,0x00,0x48,0x00,0x10,0x00,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
////////paul_rear
 const byte paul_rearblack[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x02,0x40,0x02,0x30,0x0c,0x38,0x1c,0x49,0x92,0x5e,0x7a,0x39,0x9c,0x16,0x68,0x11,0x80,0x08,0x10,0x0e,0x70};
const byte paul_rearblue[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x06,0x60,0x01,0x80,0x06,0x60,0x01,0x80,0x06,0x60,0x06,0x60,0x00,0x00};
const byte paul_rearbrown[] PROGMEM = {16,16,
0x0d,0xb0,0x0b,0xd0,0x1d,0xb8,0x1a,0x58,0x37,0xec,0x0d,0xb0,0x0b,0xd0,0x02,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
const byte paul_reargrey[] PROGMEM = {16,16,
const byte paul_rearpink[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x04,0x30,0x0c,0x0c,0x30,0x07,0xe0,0x30,0x0c,0x20,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
const byte paul_rearred[] PROGMEM = {16,16,
0x02,0x40,0x14,0x28,0x02,0x40,0x25,0xa4,0x08,0x10,0x12,0x48,0x04,0x20,0x01,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
///////paul_rear_walk1
 const byte paul_rearw1black[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x02,0x40,0x02,0x30,0x0e,0x3c,0x1a,0x49,0x9c,0x4e,0x78,0x33,0xe8,0x0e,0x88,0x0e,0x10,0x00,0x10,0x00,0x70};
const byte paul_rearw1blue[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x06,0x60,0x01,0x80,0x0c,0x00,0x00,0x60,0x00,0x60,0x00,0x60,0x00,0x00};
const byte paul_rearw1brown[] PROGMEM = {16,16,
const byte paul_rearw1grey[] PROGMEM = {16,16,
const byte paul_rearw1pink[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x04,0x30,0x0c,0x0c,0x30,0x03,0xe4,0x30,0x00,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
const byte paul_rearw1red[] PROGMEM = {16,16,
///////paul_rear_walk2
const byte paul_rearw2black[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x02,0x40,0x02,0x70,0x0c,0x58,0x1c,0x39,0x92,0x1e,0x72,0x17,0x4c,0x11,0x70,0x08,0x70,0x08,0x00,0x0e,0x00};
const byte paul_rearw2blue[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x06,0x60,0x01,0x80,0x00,0x30,0x06,0x00,0x06,0x00,0x06,0x00,0x00,0x00};
const byte paul_rearw2brown[] PROGMEM = {16,16,
const byte paul_rearw2grey[] PROGMEM = {16,16,
const byte paul_rearw2pink[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x04,0x30,0x0c,0x0c,0x30,0x27,0xc,0x00,0x0c,0x00,0x0c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
const byte paul_rearw2red[] PROGMEM = {16,16,
////////paul_right
 const byte paul_rightblack[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x00,0x28,0x00,0x08,0x00,0x08,0x06,0x10,0x07,0xe0,0x04,0x00,0x04,0xc0,0x07,0x20,0x04,0x20,0x03,0x80,0x03,0xc0};
const byte paul_rightblue[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc0,0x00,0x00,0x00,0x40,0x00,0x40,0x00,0x40,0x00,0x00};
const byte paul_rightbrown[] PROGMEM = {16,16,
0x1b,0x70,0x15,0xb0,0x2e,0xd8,0x37,0x7c,0x1b,0x80,0x2d,0x00,0x11,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
const byte paul_rightgrey[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x03,0x80,0x00,0x00,0x00,0x00};
const byte paul_rightpink[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x00,0xd0,0x06,0xd0,0x07,0xf0,0x01,0xe0,0x00,0x00,0x03,0x00,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
const byte paul_rightred[] PROGMEM = {16,16,
0x04,0x80,0x2a,0x48,0x11,0x24,0x08,0x80,0x24,0x00,0x12,0x00,0x08,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
////////paul_right_walk
 const byte paul_rightwblack[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x00,0x28,0x00,0x08,0x00,0x08,0x06,0x10,0x07,0x20,0x19,0xf8,0x29,0x24,0x27,0xc8,0x22,0x48,0x24,0x40,0x18,0x70};
const byte paul_rightwblue[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x00,0x00,0x00,0x00,0x00,0xc0,0x00,0x00,0x10,0x18,0x18,0x10,0x1c,0x30,0x18,0x30,0x00,0x00};
const byte paul_rightwbrown[] PROGMEM = {16,16,
0x17,0x70,0x1b,0xb0,0x2d,0xd8,0x36,0xfc,0x1b,0x80,0x2d,0x00,0x11,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
const byte paul_rightwgrey[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc0,0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00};
const byte paul_rightwpink[] PROGMEM = {16,16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x00,0xd0,0x06,0xd0,0x07,0xf0,0x01,0xe0,0x00,0x00,0x06,0x00,0x06,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
const byte paul_rightwred[] PROGMEM = {16,16,
0x08,0x80,0x24,0x48,0x12,0x24,0x09,0x00,0x24,0x00,0x12,0x00,0x08,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
const byte rock_black[] PROGMEM = {16,16,
B00010101,B10110100,B00001101,B10001110,B00001101,B10001101,B00001101,B10000101,B00001001,B10000101,B00001001,B10000001,B00001001,B10000110,B00001011,B00000010,B00001001,B10000001,B00011001,B10000001,B00111011,B10000011,B00100011,B11000010,B01000001,B10000010,B01000001,B10000010,B00000001,B11000111,B10000001,B10100110};
const byte rock_beige[] PROGMEM = {16,16,
B00001000,B00001000,B00000010,B00000001,B00000010,B00000000,B10000010,B00000000,B10000100,B00000000,B00000100,B00000000,B00000100,B00011001,B00000100,B00100001,B00000100,B00100000,B00000100,B00010000,B10000100,B00100000,B10011100,B00000001,B00100000,B01000001,B00100000,B01000001,B01000000,B00000000,B01010010,B0011001};
const byte rock_brown[] PROGMEM = {16,16,
B11100010,B01000011,B11110000,B01110000,B11110000,B01110010,B01110000,B01111010,B01110010,B01111010,B11110010,B01111110,B11110010,B01100000,B11110010,B01011100,B11110010,B01011110,B11100010,B01011110,B01000000,B01011100,B01000000,B00111100,B10011110,B00111100,B10011110,B00111100,B10111110,B00111000,B00101100,B01000000};
const byte sand_brown[] PROGMEM = {16,16,
B00010001,B00010001,B00000000,B00000000,B10001000,B10001000,B00000000,B00000000,B00010001,B00010001,B00000000,B00000000,B10001000,B10001000,B00000000,B00000000,B00010001,B00010001,B00000000,B00000000,B10001000,B10001000,B00000000,B00000000,B00010001,B00010001,B00000000,B00000000,B10001000,B10001000,B00000000,B00000000};
const byte sand_beige[] PROGMEM = {16,16,
B11101110,B11101110,B11111111,B11111111,B01110111,B01110111,B11111111,B11111111,B11101110,B11101110,B11111111,B11111111,B01110111,B01110111,B11111111,B11111111,B11101110,B11101110,B11111111,B11111111,B01110111,B01110111,B11111111,B11111111,B11101110,B11101110,B11111111,B11111111,B01110111,B01110111,B11111111,B11111111};
const byte blank_tile1[] PROGMEM = {16,16,
B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000};
const byte blank_tile2[] PROGMEM = {16,16,
const byte blank_tile3[] PROGMEM = {16,16,
const byte *spritesheet1[] = {blank_tile1,rock_black,};
const byte *spritesheet2[] = {blank_tile2, rock_brown, sand_brown,};
const byte *spritesheet3[] = {blank_tile3, rock_beige, sand_beige,};
///black
const byte tilemap1[] PROGMEM = {16,16,
15,20,
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,0,0,0,1,1,1,1,1,0,0,0,0,0,1,1,1,1,0,0,
0,0,0,0,1,1,1,1,0,0,0,0,0,0,1,1,1,1,0,0,
1,1,1,1,1,1,1,0,0,0,0,0,0,0,0,1,1,1,1,1,
1,1,1,1,1,1,1,1,0,0,0,0,0,0,1,1,1,1,1,1,
1,1,1,1,1,1,1,1,0,0,0,0,0,1,1,1,1,1,1,1,
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,};
///brown
const byte tilemap2[] PROGMEM = {16,16,
15,20,
2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,
2,2,2,2,1,1,1,1,2,2,2,2,2,2,1,1,1,1,2,2,
1,1,1,1,1,1,1,2,2,2,2,2,2,2,2,1,1,1,1,1,
1,1,1,1,1,1,1,1,2,2,2,2,2,2,1,1,1,1,1,1,
1,1,1,1,1,1,1,1,2,2,2,2,2,1,1,1,1,1,1,1,
2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,};
///beige
const byte tilemap3[] PROGMEM = {16,16,
15,20,
    Serial.begin(921600);
    long unsigned debug_start = millis();
    while (!Serial && (millis() < 4000)) ;
  tft.begin();
//   tft.titleScreen(F("Dune esp demo"));
  tft.setFrameRate(62);
  tft.persistence = false;
  tft.setRotation(1);
  tft.fillScreen(BLACK);
//tft.drawTilemap2(x, y, tilemap1, spritesheet1, BLACK);
tft.drawTilemap(spritesheet2);
//tft.drawTilemap2(x, y, tilemap2, spritesheet3, LIGHTBROWN);
void loop(void) {
//updates the GameRIot (the display, the sound, the buttons, everyyhing)
   if(tft.updateAll()){
    if (tft.buttons.repeat(BTN_RIGHT,1));//{X--:}
    if (tft.buttons.repeat(BTN_LEFT,1));//{X++:}
    if (tft.buttons.repeat(BTN_DOWN,1));//{Y--:}
    if (tft.buttons.repeat(BTN_UP,1));//{Y--:}
//tft.drawTilemap(x, y, tilemap1, spritesheet1, BLACK);
//  tft.drawTilemap(x, y, tilemap2, spritesheet2, BROWN);
 //  tft.drawTilemap(x, y, tilemap3, spritesheet3, LIGHTBROWN);
    if (tft.buttons.repeat(BTN_UP,1)){
       tft.drawBitmap1(player_x, player_y,paul_rearblack,16,16,BLACK);
         tft.drawBitmap1(player_x, player_y,paul_rearblue,16,16,BLUE);
          tft.drawBitmap1(player_x, player_y,paul_rearbrown,16,16,BROWN);
          tft.drawBitmap1(player_x, player_y,paul_reargrey,16,16,GREY);
           tft.drawBitmap1(player_x, player_y,paul_rearpink,16,16,PINK);
            tft.drawBitmap1(player_x, player_y,paul_rearred,16,16,YELLOW);
            player_direction = 1;
             player_y = player_y - 1;}
            if(player_y <= 0){
              player_y = 0;}
       if (tft.buttons.repeat(BTN_DOWN,1)){
        tft.drawBitmap1(player_x, player_y,paul_frontblack,16,16,BLACK);
         tft.drawBitmap1(player_x, player_y,paul_frontblue,16,16,BLUE);
          tft.drawBitmap1(player_x, player_y,paul_frontbrown,16,16,BROWN);
          tft.drawBitmap1(player_x, player_y,paul_frontgrey,16,16,GREY);
          tft.drawBitmap1(player_x, player_y,paul_frontgreen,16,16,GREEN);
           tft.drawBitmap1(player_x, player_y,paul_frontpink,16,16,PINK);
            tft.drawBitmap1(player_x, player_y,paul_frontred,16,16,RED);
             player_y = player_y + 1;}
            if(player_y <= 40){
              player_y = 40;}
       if (tft.buttons.repeat(BTN_LEFT,1)){
        tft.drawBitmap1(player_x, player_y,paul_leftblack,16,16,BLACK);
         tft.drawBitmap1(player_x, player_y,paul_leftblue,16,16,BLUE);
          tft.drawBitmap1(player_x, player_y,paul_leftbrown,16,16,BROWN);
          tft.drawBitmap1(player_x, player_y,paul_leftgreen,16,16,GREEN);
          tft.drawBitmap1(player_x, player_y,paul_leftgrey,16,16,GREY);
           tft.drawBitmap1(player_x, player_y,paul_leftpink,16,16,PINK);
            tft.drawBitmap1(player_x, player_y,paul_leftred,16,16,RED);
            player_direction = 3;
             player_x = player_x - 1;}
            if(player_x <= -2){
              player_x = -2;}
        if (tft.buttons.repeat(BTN_RIGHT,1)){
        tft.drawBitmap1(player_x, player_y,paul_rightblack,16,16,BLACK);
         tft.drawBitmap1(player_x, player_y,paul_rightblue,16,16,BLUE);
          tft.drawBitmap1(player_x, player_y,paul_rightbrown,16,16,BROWN);
          tft.drawBitmap1(player_x, player_y,paul_rightbrown,16,16,GREY);
           tft.drawBitmap1(player_x, player_y,paul_rightpink,16,16,PINK);
            tft.drawBitmap1(player_x, player_y,paul_rightred,16,16,RED);
           if(player_x <= -2){
              player_x = -2;}
       /////////////////PLAYER DIRECTION/////////////////
        if (player_direction == 1){
look in subsection bitmaps for both .cpp and .h. most of the library matches the other in placement of functions and definitions
PostPosted: Sun May 28, 2017 1:36 pm
by awesome101
Can you post the cpp and h files in code brackets I'm on an iPad so I can't open zip files
Or just post the drawTilemap function
PostPosted: Sun Jun 18, 2017 9:19 am
by Duhjoker
Ok I think I'm on the right track.When you get stuck sometimes its best to go back to the beginning. Today I started looking at the original drawbitmap functions and tilemap functions and discovered the problem. just don't know how to correct it. Since you askedlets look at my versions of the cpp functions for tilemap.
void Grafx::drawTilemap(int x, int y, const uint8_t *tilemap, const uint8_t **spritesheet, uint16_t color) {
   drawTilemap(x, y, tilemap, spritesheet, 0, 0, Grafx_TFTWIDTH, Grafx_TFTHEIGHT, color);
void Grafx::drawTilemap(int x, int y, const uint8_t *tilemap, const uint8_t **spritesheet, uint16_t dx, uint16_t dy, uint16_t dw, uint16_t dh, uint16_t color) {
   uint16_t tilemap_width = pgm_read_byte(tilemap);
   uint16_t tilemap_height = pgm_read_byte(tilemap + 1);
   uint16_t tile_width = pgm_read_byte(tilemap + 2);
   uint16_t tile_height = pgm_read_byte(tilemap + 3);
   tilemap += 4; // now the first tiyleis at tilemap
   uint16_t ddw = dw + dx;
   uint16_t ddh = dh + dy;
   uint16_t maxDdx = (dw - x + tile_width - 1) / tile_width;
   uint16_t maxDdy = (dh - y + tile_height - 1) / tile_height;
   if (tilemap_width < maxDdx) {
      maxDdx = tilemap_width;
   if (tilemap_height < maxDdy) {
      maxDdy = tilemap_height;
   int16_t startDdx = (-x) / tile_width;
   int16_t startDdy = (-y) / tile_height;
   if (startDdx < 0) {
      startDdx = 0;
   if (startDdy < 0) {
      startDdy = 0;
   if (flagcollision)numcolision = 0;                                 //Line 735 - clear numcolision - ADD by Summoner123
   for (uint16_t ddy = startDdy; ddy < maxDdy; ddy++) {
      for (uint16_t ddx = startDdx; ddx < maxDdx; ddx++) {
         int16_t drawX = ddx*tile_width + x + dx;
         int16_t drawY = ddy*tile_height + y + dy;
         uint16_t tile = pgm_read_byte(tilemap + ddy*tilemap_width + ddx);
         if (drawX >= dx && drawY >= dy && drawX <= (ddw - tile_width) && drawY <= (ddh - tile_height)) {
            drawBitmapTM1(drawX, drawY, tile_width, tile_height, spritesheet[tile], color);
            if (flagcollision) {
               solid[numcolision].x = drawX;                     //Save X coordinate      - ADD by Summoner123
               solid[numcolision].y = drawY;                     //Save Y coordinate      - ADD by Summoner123
               solid[numcolision].spritecol = spritesheet[tile]; //Save Sprite of tile    - ADD by Summoner123
               numcolision++;                                    //Increment numcolision  - ADD by Summoner123
         else { // we need to draw a partial bitmap
            drawBitmapTm(drawX, drawY, tile_width, tile_height, spritesheet[tile], dx, dy, dw, dh, color);
it uses two different bitmap functions. One with parameters like this.....
and one that works like this.........
theres nothing wrong with the first but a lot wrong with the second. Its asking a bitmap function that has those arguments so I gave it a bitmap with those arguments. the problem is that yes its looking for those arguments but more added to it to actually do the tiles. That can be found here.......
void Display::drawBitmap(int8_t x, int8_t y, int8_t w, int8_t h , const uint8_t *bitmap) {
#if (ENABLE_BITMAPS > 0)
/*   original code
    int8_t i, j, byteWidth = (w + 7) / 8;
    for (j = 0; j < h; j++) {
        for (i = 0; i < w; i++) {
            if (pgm_read_byte(bitmap + j * byteWidth + i / 8) & (B10000000 >> (i % 8))) {
                drawPixel(x + i, y + j);
  uint8_t * buffer = getBuffer();
  const uint8_t col = color;
  const uint8_t bw = (w+7) / 8;
  // clip
  if (x >= LCDWIDTH)
    return;
  if (x + w <= 0)
    return;
  if (y >= LCDHEIGHT)
    return;
  if (y + h <= 0)
    return;
  if (y < 0)
    h += y, bitmap -= bw * y, y = 0;
  if (y + h > LCDHEIGHT)
    h = LCDHEIGHT - y;
  uint8_t x1 = max(0, x);
  uint8_t x2 = min(LCDWIDTH, x + w);
#ifdef ENABLE_GRAYSCALE
   uint8_t g = y ^ frameCount;
#endif
  // draw
  uint8_t first_bitmap_mask = 0x80 >> ((x1 - x) & 7);
  const uint8_t * bitmap_line = bitmap + (x1 - x) / 8;
  uint8_t screen_mask = 0x01 << (y % 8);
  uint8_t * screen_row = buffer + (y / 8) * LCDWIDTH + x1;
  for (uint8_t dy=0; dy<h; dy++, bitmap_line+=bw)
    const uint8_t * bitmap_ptr = bitmap_line;
    uint8_t bitmap_mask = first_bitmap_mask;
    uint8_t pixels = pgm_read_byte(bitmap_ptr);
    uint8_t * dst = screen_row;
    if (col == BLACK)
      for (uint8_t sx=x1; sx<x2; sx++, dst++)
        if (pixels & bitmap_mask)
          *dst |= screen_mask;
        bitmap_mask >>= 1;
        if (!bitmap_mask)
          bitmap_mask = 0x80;
          pixels = pgm_read_byte(++bitmap_ptr);
    else if (col == WHITE)
      uint8_t inv_screen_mask = ~screen_mask;
          *dst &= inv_screen_mask;
        bitmap_mask >>= 1;
        if (!bitmap_mask)
          bitmap_mask = 0x80;
    else if (col == GRAY)
         if ((sx^g) & 1)
          else
        bitmap_mask >>= 1;
        if (!bitmap_mask)
          bitmap_mask = 0x80;
       g ^= 1;
#endif
   else // invert
          *dst ^= screen_mask;
        bitmap_mask >>= 1;
        if (!bitmap_mask)
          bitmap_mask = 0x80;
    screen_mask <<= 1;
    if (!screen_mask)
      screen_mask = 1;
      screen_row += LCDWIDTH;
#else
   drawRect(x, y, w, h);
#endif
without enabling bitmaps nets you a square grid but what its looking for are these set of code lines......
I worked on it a lil and can get a grid of squares but figure out how to disable the enable bitmaps part or add the needed lines to a drawbitmap function using those arguments.
The buffer and grey scale parts aren't needed we use color names in the arguments also the buffer stuff is not needed. We just need the dy dh stuff
PostPosted: Mon Jun 19, 2017 9:59 am
by Duhjoker
Well there is nothing wrong with the drawtilemap(). It works just the way i updated it to work. I got bored today and successfully transplanted and updated the original gamebuino tilemap and bitmap functions. This did not help but was good practice.
For some reason that i cant recall i decided to play with placement of the tilemap and i noticed every time i upped the integer more map would show but it was just placing it lil over to the left. But the tiles are being printed.
There is some kinda offset thats causing the problem. And its proportional. If you rotate the screen the blank spot moves with it. Other wise my player sprite moves and shows up in the blank area. I can fill screen just fine and every thing else but not with any function calling more than one bitmap in an array.
