Has anyone used this on Windows 8.1? I can install it but after starting the Simbuino.application file there is a short window burst then it closes out and doesn't seem to be running. Any help would be much appreciated!
-Tre
treflip wrote:I can install it but after starting the Simbuino.application file there is a short window burst then it closes out and doesn't seem to be running.
mougino wrote:... a lot in my current project (a Fighting Fantasy gamebook enging)
Nicolas
mougino wrote:Anyway I just found that gbsim runs at 58/59 fps on my netbook, but the default framerate on the Gamebuino is 20 fps... So I was a little surprised after developing and testing on gbsim to put the HEX on my Gamebuino and to see it run so fast
Thanks for the feedback, and keep up the good work !
Deneth wrote:Do you have the version with the number in the top corner? I think that's the emulation speed, where 100 is full speed. On the laptop I had at the time it was about 90. I thought the emulator had speed limiting. Is the number 100 on your computer? If so, I might need to look at how the frame rate is implemented, and check that the simulated AVR core is configured for it
Users browsing this forum: No registered users and 126 guests
