If your really interested I can handle the player sprites and terrain, what we need is some nice looking 8 bit monsters original or not. You pick!
Edit::: really thank you summoner123 will look at all soon
int x=-50,y=50;
int x=0,y=0;
const byte tilemap[] PROGMEM = {15,9,
8,8,
2,2,2,2,2,2,2,8,8,2,2,2,2,2,2,
2,2,2,2,2,1,4,8,8,2,2,2,2,2,2,
2,2,2,2,4,8,8,8,8,2,2,2,2,2,2,
2,2,2,4,8,8,8,8,8,2,2,2,2,2,2, /////////112x64 pix res
2,2,4,8,8,8,8,8,8,3,2,2,2,2,2,
8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,
2,2,8,8,8,8,8,8,8,8,8,8,8,2,2,
2,2,2,2,2,2,2,2,2,2,2,2,2,2,2};
const byte bush[] PROGMEM = {B00101100,B01010010,B10001001,B01000010,B10010001,B01001010,B00100100,B01111110,};
const byte port_noir[] PROGMEM = {B11111111,B11111111,B11111111,B11111111,B11111111,B11111111,B11111111,B11111111,};
const byte rock_terrain_master[] PROGMEM = {B01001101,B10100100,B10010001,B01001010,B10010000,B01100101,B10001001,B01011010,};
const byte rock_valley_ne[] PROGMEM = {B10101010,B10010101,B01000100,B00101001,B00110010,B00001010,B00000100,B00000011,};
const byte rock_valley_nw[] PROGMEM = {B01010101,B10101001,B00100010,B10010100,B01001100,B01010000,B00100000,B11000000,};
const byte rock_valley_se[] PROGMEM = {B00000011,B00000100,B0011001,B00010010,B00101001,B01000110,B10110001,B10001010,};
const byte rock_valley_sw[] PROGMEM = {B11000000,B00100000,B10011000,B01001000,B10010100,B01100010,B10001101,B01010001,};
const byte turtle_rock[] PROGMEM = {B01101100,B10110010,B11010001,B01010101,B01010010,B10011001,B10000001,B11111110,};
const byte void_tile[] PROGMEM = {B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,};
const byte water_left_bottom[] PROGMEM = {B10001111,B10000000,B11110000,B10000000,B10001111,B10000000,B11110000,B11111111,};
const byte water_left_middle[] PROGMEM = {B10001111,B10000000,B11110000,B10000000,B10001111,B10000000,B11110000,B10000000,};
const byte water_left_top[] PROGMEM = {B11111111,B10000000,B11110000,B10001111,B10000000,B10000000,B11110000,B10000000,};
const byte water_right_bottom[] PROGMEM = {B1110001,B00000001,B0000111,B00000001,B11110001,B00000001,B00001111,B11111111,};
const byte water_right_middle[] PROGMEM = {B11110001,B00000001,B00001111,B00000001,B11110001,B00000001,B00001111,B00000001,};
const byte water_right_top[] PROGMEM = {B11111111,B00000001,B00001111,B00000001,B11110001,B00000001,B00001111,B00000001,};
const byte water_middle_bottom[] PROGMEM = {B11110000,B00000000,B00001111,B00000000,B11110000,B00000000,B00001111,B11111111,};
const byte water_middle_middle[] PROGMEM = {B11110000,B00000000,B00001111,B00000000,B11110000,B00000000,B00001111,B00000000,};
const byte water_middle_top[] PROGMEM = {B11111111,B00000000,B11110000,B00000000,B00001111,B00000000,B11110000,B00000000,};
const byte *spritesheet[] = {bush, port_noir, rock_terrain_master, rock_valley_ne,
rock_valley_nw, rock_valley_se, rock_valley_sw, turtle_rock, void_tile, water_left_bottom,
water_left_middle, water_left_top, water_right_bottom, water_right_middle, water_right_top,
water_middle_bottom, water_middle_middle, water_middle_top};
const byte sever_front_black[] PROGMEM = {8,8,0x39,0x7d,0x01,0x01,0xfe,0x01,0x7c,0x46};
const byte sever_front_grey[] PROGMEM = {8,8,0x82,0x82,0xd6,0x7c,0x01,0xa8,0x00,0x00,};
const byte sever_right_black[] PROGMEM = {8,8,0x9f,0xbe,0x80,0x82,0x7f,0x00,0x3e,0x62,};
const byte sever_right_grey[] PROGMEM = {8,8,0x00,0x00,0x17,0x3c,0x00,0x95,0x00,0x00,};
const byte sever_rear_black[] PROGMEM = {8,8,0x9c,0xbe,0xbe,0x80,0x7f,0x88,0x3e,0x62,};
const byte sever_rear_grey[] PROGMEM = {8,8,0x41,0x41,0x7f,0x3e,0x80,0x15,0x00,0x00,};
const byte sever_left_black[] PROGMEM = {8,8,0xf9,0x7d,0x01,0x41,0xfe,0x00,0x7c,0x46,};
const byte sever_left_grey[] PROGMEM = {8,8,0x00,0x00,0xe8,0x3c,0x00,0xa9,0x00,0x00,};
int player_x = 70; //cant get these to center
int player_y = 70; //cant get these to center
int player_direction = 0;
int x=-50,y=50; ///if 0 player spite will not move, -50,50 no tilemap
gb.titleScreen(F("test"));
gb.setFrameRate(62); ////////for sprite
/////////PLAYER_MOVEMENT\\\\\\\\\
if (gb.buttons.repeat(BTN_RIGHT,1));//{x--;}
if (gb.buttons.repeat(BTN_LEFT,1));//{x++;}
if (gb.buttons.repeat(BTN_DOWN,1));//{y--;}
if (gb.buttons.repeat(BTN_UP,1));//{y++;}
// gb.display.cursorY = 12; gb.display.println( x );gb.display.println( y );
gb.display.setColor(BLACK);{
gb.display.drawBitmap(player_x,player_y,sever_rear_black);
gb.display.setColor(GRAY);{
gb.display.drawBitmap(player_x,player_y,sever_rear_grey);
player_direction = 1;
player_y = player_y - 1;
if(checkcolision())player_y++; // ADD by Summoner123 - If have colision on the new position regreat one Pixel
if(player_y <= 0){
player_y = 0;}
gb.display.drawBitmap(player_x,player_y,sever_front_black);
gb.display.drawBitmap(player_x,player_y,sever_front_grey);
player_direction = 2;
player_y = player_y + 1;
if(checkcolision())player_y--; // ADD by Summoner123 - If have colision on the new position regreat one Pixel
if(player_y >= 40){
player_y = 40;}
gb.display.drawBitmap(player_x,player_y,sever_right_black);
gb.display.drawBitmap(player_x,player_y,sever_right_grey);
player_direction = 3;
player_x = player_x + 1;
if(checkcolision())player_x--; // ADD by Summoner123 - If have colision on the new position regreat one Pixel
if(player_x >= 77){
player_x = 77;}
gb.display.drawBitmap(player_x,player_y,sever_left_black);
gb.display.drawBitmap(player_x,player_y,sever_left_grey);
player_direction = 4;
player_x = player_x - 1;
if(checkcolision())player_x++; // ADD by Summoner123 - If have colision on the new position regreat one Pixel
if(player_x <= -2){
player_x = -2;}
if (player_direction == 1){
else { gb.display.setColor(BLACK);{
bool checkcolision() // Transformed it into a function
uint16_t i;
if(gb.collideRectRect(player_x,player_y,8,8,gb.display.solid[i].x,gb.display.solid[i].y,8,8))///changed player_x,y back to 8
if(gb.display.solid[i].spritecol == void_tile); //Do nothing because it's floor - This line not needed
if(gb.display.solid[i].spritecol == bush);
else if(gb.display.solid[i].spritecol == port_noir);
else if(gb.display.solid[i].spritecol == rock_terrain_master); //{gb.popup(F(" ""Rock"" "),1); return true;} //Return True if character have touched the wall
else if(gb.display.solid[i].spritecol == rock_valley_ne);
else if(gb.display.solid[i].spritecol == rock_valley_nw);
else if(gb.display.solid[i].spritecol == rock_valley_se);
else if(gb.display.solid[i].spritecol == rock_valley_sw);
else if(gb.display.solid[i].spritecol == turtle_rock);
else if(gb.display.solid[i].spritecol == water_left_bottom);
else if(gb.display.solid[i].spritecol == water_left_middle);
else if(gb.display.solid[i].spritecol == water_left_top);
else if(gb.display.solid[i].spritecol == water_right_bottom);
else if(gb.display.solid[i].spritecol == water_right_middle);
else if(gb.display.solid[i].spritecol == water_right_top);
else if(gb.display.solid[i].spritecol == water_middle_bottom);
else if(gb.display.solid[i].spritecol == water_middle_middle);
else if(gb.display.solid[i].spritecol == water_middle_top);
//return false; // Return false if don't touch anything
if(player_x > 64 ) {camerax-=2; player_x -=2;} //Y Scrolling right
else if(player_x < 10 ){camerax+=2; player_x +=2;} //Y Scrolling left
if(player_y > 28 ) {cameray-=2; player_y -=2;} //Y Scrolling Down
else if(player_y < 10 ){cameray+=2; player_y +=2;} //Y Scrolling Up
gb.display.drawTilemap(camerax,cameray,tilemap,spritesheet); // draw the tilemap
extern const byte sever_front_black[];
extern const byte sever_front_grey[]
... etc
Users browsing this forum: No registered users and 77 guests
