GPS Locator project.
Postby Georgian » Sat Aug 27, 2016 5:09 pm
Hi guys,
I'm planning to make a "game" for gamebuino that shows the GPS location and some other info on the screen. I'll have to make a small board and use the i2c connector for software serial. All fine with that. I'll keep posting as I advance if you guys are intersted. I'm not an professional so do expect some bugs in my code :D
PS: Can I use the SD card for data logging? Like create a folder and make files just like if the hex was burnt on the Atmega chip not in the SD? Hope you understand what i mean.
EDIT**:
I just looked on the battery logger example and i see that the SD card can be used as normal. :D
Georgian
Re: GPS Locator project.
Postby Georgian » Sat Aug 27, 2016 7:51 pm
I will use the PA6H GPS because i have some experience with it and it is very small. Here is the board that I made. 17.5MM X 24.5MM
https://oshpark.com/shared_projects/eTsFID4R
GPS addon.zip
Eagle files
(47.63 KiB) Downloaded 825 times
Georgian
Postby Georgian » Mon Aug 29, 2016 7:50 pm
So, this is what i have done so far. The code it's quite messy but it works. Should work with any GPS device but you will have to change the output to RMC only. Maybe the coordinates should be in degree format instead of decimal?
#include <SoftwareSerial.h>
SoftwareSerial GPS(A4, A5); //GPS is connected on i2c port
//gps stuff
#define GPSBUFFSIZE 100
char gpsBuff[GPSBUFFSIZE];
//char time[7];
//Variable for MENU
#define MENULENGTH   3
const char strLiveDATA[] PROGMEM = "View GPS DATA";
const char strLogDATA[] PROGMEM = "Start GPS Logger";
const char strEXIT[] PROGMEM = "EXIT";
const char* const menu[MENULENGTH] PROGMEM = {
   strLiveDATA,
   strLogDATA,
   strEXIT,
char folderName[9] = "GPSLOG";
   GPS.begin(9600);
   delay(500);
   gb.titleScreen(F("GPS Position :)"));
   gb.popup(F("Welcome :)"), 100);
   gb.battery.show = true;
   GPS.print(F("$PMTK314,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*29\r\n"));
   delay(500);
   switch(gb.menu(menu, MENULENGTH)) {
      case -1: {
         break;
      case 0: {
         liveDATA();
         break;
      case 1: {
         logDATA();
         break;
      case 2: {
         gb.changeGame();
         break;
      default: {
         break;
void liveDATA() {
   while(1) {
      if(gb.update()) {
         if (gb.buttons.pressed(BTN_C)) {
            return;
      if (!processGPS(false)) {
         gb.display.println(F("Searching..."));
         Serial.println(F("NO FIX"));
void logDATA() {
   gb.keyboard(folderName, 9);
   while(1) {
      if(gb.update()) {
            return;
         gb.display.print(F("Folder name: "));
         gb.display.println(folderName);
boolean processGPS(boolean toLOG) {
   byte i = 0;
   memset(gpsBuff, '\0', GPSBUFFSIZE);
   while(GPS.available()) GPS.read(); //Empty the buffer before we read and parse!
   while(1) {
      if (GPS.available() > 0) {
         char c = GPS.read();
         gpsBuff[i] = c;
         //Serial.print(c);
         i++;
         if (c == '\n') {
            gpsBuff[i] = 0;
            break;
         if (i == GPSBUFFSIZE -1) {
            gpsBuff[i] = 0;
            break;
   if (gpsBuff[18] != 'A') {
      return false;
   } else if (gpsBuff[18] == 'A') { //We have a FIX!
      char time[7];
      float flat, flong;
      //$GPRMC,190411.000,A,4815.0434,N,01417.4215,E,2.99,100.48,271015,,,A*67\r\n
      strtok_P(gpsBuff, PSTR (","));
      strcpy(time, strtok_P(NULL, PSTR (".")));
      strtok_P(NULL, PSTR (","));
      flat = atof(strtok_P(NULL, PSTR (",")));
      flat = conv_coords(flat);
      if (strtok_P(NULL, PSTR (",")) != "N") {
         flat = flat * -1;
      flong = atof(strtok_P(NULL, PSTR (",")));
      flong = conv_coords(flong);
      if (strtok_P(NULL, PSTR (",")) != "E") {
         flat = flat * -1;
      gb.display.print(F("UTC time: "));
      gb.display.print(time[0]);
      gb.display.print(time[1]);
      gb.display.print(F(":"));
      gb.display.print(time[2]);
      gb.display.print(time[3]);
      gb.display.print(time[4]);
      gb.display.println(time[5]);
      gb.display.print(F("LAT: ")); gb.display.println(flat, 6);
      gb.display.print(F("LON: ")); gb.display.println(flong, 6);
      return true;
   return false;
float conv_coords(float in_coords) {
   //Initialize the location.
   float f = in_coords;
   // Get the first two digits by turning f into an integer, then doing an integer divide by 100;
   // first two digits should be 77 at this point.
   int firsttwodigits = ((int)f)/100;                               //This assumes that f < 10000.
   float nexttwodigits = f - (float)(firsttwodigits*100);
   float theFinalAnswer = (float)(firsttwodigits + nexttwodigits/60.0);
   return theFinalAnswer;
Georgian
Postby Georgian » Tue Aug 30, 2016 8:27 pm
Can someone help me with this pice of code?
I want to increment a counter every time a line is writen to the SD card. Dose the file.write() function returnes true when finished writing?
Here is the part of code:
if (file.writeLn(gpsBuff)) {
               count++;
            } else {
               errCount++;
So only the errCount is incremented. Is there any other way to do it?
Thanks.
Georgian
Postby Georgian » Tue Aug 30, 2016 9:17 pm
I got it working with a small modification.
if (file.writeLn(gpsBuff) == NO_ERROR) {
               count++;
            } else {
               errCount++;
Now the counter increments but there is nothing in the file. The file is empty but it dose have a few Kilobytes.
I tried to run the battery logger exemple from the gamebuino library with the same results.
This line dose not add any text to the file:
file.writeLn("I will log battery voltage every 10 minutes");
Georgian
Postby Georgian » Wed Aug 31, 2016 8:14 pm
I managed to solve the issue by using the sdFAT library instead of tinyFAT.
Georgian
Postby Georgian » Sat Sep 03, 2016 7:17 pm
Finaly i have managed to finish it. On my desk it works just fine, still need to do some tests outside.
If you chose to log the data, you will be prompted to enter the file name. The name must be no longer than 8 chars. The ".TXT" extensien will be added after. The second menu is the interval. Press the down arraw to toggle the light and thats it. You are free to do whatever you want with this code. Have fun playing :)
//#include <tinyFAT.h> //requires the tinyFAT library. You can download it here : http://www.henningkarlsen.com/electronics/library.php?id=37
#include <SdFat.h>
#define SD_CS_PIN SS
extern const byte font3x3[]; //a really tiny font
extern const byte font3x5[]; //a small but efficient font (default)
extern const byte font5x7[]; //a large, comfy font
//gps stuff
#define GPSBUFFSIZE 90
//char time[7];
//Variable for MAIN MENU
   strLiveDATA,
   strLogDATA,
   strEXIT,
#define INTERVALMENULENGTH   3
const char str5[] PROGMEM = "5s";
const char str10[] PROGMEM = "10s";
const char str20[] PROGMEM = "20S";
const char* const intervalMenu[MENULENGTH] PROGMEM = {
   str5,
   str10,
   str20,
SdFat SD;
File myFile;
char fileNAME[15] = "GPSLOG";
boolean light = false;
long timer = 0;
   GPS.begin(9600);
   delay(500);
   gb.backlight.set(0);
   //gb.display.setFont(font5x7);
   gb.display.setFont(font3x5);
   gb.display.fontSize = 2;
   //gb.popup(F("Welcome :)"), 100);
   delay(500);
   //gb.setFrameRate(1);
      case -1: {
         break;
      case 0: {
         liveDATA();
         break;
      case 1: {
         logDATA();
         break;
      case 2: {
         gb.changeGame();
         break;
      default: {
         break;
void liveDATA() {
   while(1) {
      if(gb.update()) {
            return;
         if (gb.buttons.pressed(BTN_DOWN)) {
            light = !light;
         if (light) {
            gb.backlight.set(200);
            } else {
void logDATA() {
   int count = 0;
   byte errCount = 0;
   if (!SD.begin(SD_CS_PIN)) {
      gb.display.clear();
      gb.display.update();
      gb.display.println(F("NO SD!"));
      while(1);
   delay(500);
   gb.keyboard(fileNAME, 8);
   char fname[15];
   sprintf_P(fname, PSTR ("%s.TXT"), fileNAME);
   int interval = 0;
   //while(1) {
      switch(gb.menu(intervalMenu, INTERVALMENULENGTH)) {
         case -1: {
            interval = 100;
            break;
         case 0: {
            interval = 100;
            break;
         case 1: {
            interval = 200;
            break;
         case 2: {
            interval = 400;
            break;
         default: {
            interval = 100;
            break;
   myFile = SD.open(fname, FILE_WRITE);
   if (!myFile) {
      gb.display.clear();
      gb.display.println(F("File ERROR!"));
      gb.display.println(fname);
      while(1);
   while(1) {
      if(gb.update()) {
            myFile.close();
            return;
            light = !light;
         if (light) {
         } else {
         if (gb.frameCount - timer >= interval) {
            if (processGPS(true)) {
               if (myFile.print(gpsBuff)) {
                  count++;
               } else {
                  errCount++;
            } else {
            timer = gb.frameCount;
         gb.display.print(F("Stored: ")); gb.display.println(count);
         gb.display.print(F("failed: ")); gb.display.println(errCount);
         //gb.display.println(gb.frameCount);
         gb.display.cursorX = 0;
         gb.display.cursorY = 42;
         gb.display.print(F("Voltage: ")); gb.display.println(gb.battery.voltage);// gb.display.println(F(" mV"));
   byte i = 0;
   while(1) {
         gpsBuff[i] = c;
         //Serial.print(c);
         i++;
         if (c == '\n') {
            gpsBuff[i] = 0;
            break;
            gpsBuff[i] = 0;
            break;
      return false;
      if (toLOG) {
         return true;
      } else {
         char time[7];
         float flat, flong, fspeed;
            flat = flat * -1;
            flat = flat * -1;
         fspeed = atof(strtok_P(NULL, PSTR (",")));
         fspeed = fspeed * 1.852;
         gb.display.print(F("Speed: ")); gb.display.print(fspeed); gb.display.println(F("Km/h"));
         //gb.display.println(gb.getCpuLoad());
         return true;
   return false;
Georgian
