[SOLVED] Problems with SD
Re: [SOLVED] Problems with SD
Postby Tony » Sat Jul 19, 2014 4:08 pm
Ok thank you very much :)
Tony
Postby animus » Sat Sep 10, 2016 4:11 pm
at first thanks to rodot for the Gamebuino - such a cool little device.
A few days ago I loaded the new LOADER.HEX and SETTINGS.HEX on the provided micro SD card but when I turn it on and want to enter the Loader from game menu by pressing C the the display says "Flashing loader" and then the game shows up again.
When I try to make a Reset (Hold C down then turn on and release C) also just the game shows up.
I thought maybe the Loader is corrupted (tried everything on the Troubleshooting page) so I downloaded it again and I formated the SC card as FAT but it did not change anything.
I tryied to flash the Loader via the Arduino IDE but the PC does not recognize the Gamebuino at all when I connect it (tried different Cables).
So now I only can play the Game which is flashed to the Gamebuino but cannot change it.
Can you help me?
animus
Postby Sorunome » Sat Sep 10, 2016 8:41 pm
Did you make sure you formated the SD as fat-16?
It won't work if you format it as Fat-32!
Postby animus » Sat Sep 10, 2016 9:16 pm
Yes, I am sure. I followed the "How to format the micro SD card" section on te Troubleshooting page.
animus
Postby animus » Sat Sep 17, 2016 6:40 am
OK, I downloaded the Games-Compilation again and then it somehow worked.
Before that I tried the LOADER.HEX from: https://github.com/Rodot/Gamebuino/tree/master/hex
bit it did not work.
Anyhow, Gamebuino works again :)
animus
Users browsing this forum: No registered users and 60 guests
