Include numbers in gb.popup
Postby STUDIOCRAFTapps » Mon Oct 10, 2016 6:03 pm
Hey!
I'm trying to include numbers in popup but i get a lot of error...
      int Level = 3;
      if(gb.buttons.pressed(BTN_A))
        gb.popup(F("You beat the level " + Level), 20);
I don't know how F() works.
I alway get this error :
 in expansion of macro 'F'
STUDIOCRAFTapps
Re: Include numbers in gb.popup
Postby Duhjoker » Tue Oct 11, 2016 2:08 am
I can't "I" am going to say this,lol. But you should really check out the reference for the functions found here....
http://gamebuino.com/wiki/index.php?title=Reference
where you are trying to add an argument for the level is actually for duration of the pop up. Instead it would be easier to write a popup for each level and then have it called once per level.
Postby STUDIOCRAFTapps » Tue Oct 11, 2016 11:50 am
DON'T LAUGH ABOUT MY ORTHOGRAPH... edit: And grammar
Last edited by STUDIOCRAFTapps on Tue Oct 11, 2016 11:54 am, edited 1 time in total.
STUDIOCRAFTapps
Postby STUDIOCRAFTapps » Tue Oct 11, 2016 11:54 am
Duhjoker wrote:I can't "I" am going to say this,lol. But you should really check out the reference for the functions found here....
where you are trying to add an argument for the level is actually for a duration of the pop-up. Instead, it would be easier to write a popup for each level and then have it called once per level.
Write a popup for each level? If we replace level by score, I need to add a lot of pop-ups.
STUDIOCRAFTapps
Postby rodot » Tue Oct 11, 2016 12:19 pm
Popups only accept stings stored in PROGMEM so it doesn't eat up all the RAM. When you use F("your string"), it calls a macro that will make sure the string is stored in flash memory (aka PROGMEM) and *not* transferred to RAM when the function is called.
Pros : it saves RAM
Cons : content must be set at compilation time, it can't be dynamically changed at running time. So you can't use if for level or score, except if you create a separate string for each level as Duhjocker suggested.
Alternative solution : make your own popup function using the Arduino String class. Takes more RAM, but it would be more versatile.
Here is a short example I just made you :
String myPopupText;
byte myPopupTimeLeft;
  gb.titleScreen(F("Custom Popup"));
    if(gb.update()){ //update everything
      gb.display.println(F("Custom popups"));
      gb.display.println(gb.frameCount);
        myPopup(String("Frames = ") + gb.frameCount, 40);
      myPopupUpdate();
void myPopup(String text, byte time){
  myPopupText = text;
  myPopupTimeLeft = time;
void myPopupUpdate(){
  if (myPopupTimeLeft){
    gb.display.fontSize = 1;
    gb.display.setColor(WHITE);
    gb.display.fillRoundRect(0,LCDHEIGHT-gb.display.fontHeight-3,84,gb.display.fontHeight+3,3);
    gb.display.setColor(BLACK);
    gb.display.drawRoundRect(0,LCDHEIGHT-gb.display.fontHeight-3,84,gb.display.fontHeight+3,3);
    gb.display.cursorX = 4;
    gb.display.cursorY = LCDHEIGHT-gb.display.fontHeight-1;
    gb.display.print(myPopupText);
    myPopupTimeLeft--;
Postby naed » Thu Oct 13, 2016 12:26 am
great post Rodot and something i really needed to look at to for my current Gamebuino project
naed
