Gamebuino Mac - Ports only show /dev/tty.Bluetooth-Modem
Postby Aisjam » Sat Jan 21, 2017 12:47 pm
I have been experiencing an issue where i would like to connect my Gamebuino to my Mac however it is only showing bluetooth for the ports. I have been trying to find the correct driver for it however no luck just yet.
my Arduino can connect fine however;
- I have tried mulitple usbs, connecting it in when it is on
- reseting the computer
- following this from spark fun https://learn.sparkfun.com/tutorials/ho ... c#yosemite. even the part for yosmite
here are my specks
Mac OS: 10.10.5 Yosemite
Arduino IDE: 1.8.1
Is anyone having this issue for mac? What OS version do you have.
Aisjam
Re: Gamebuino Mac - Ports only show /dev/tty.Bluetooth-Modem
Postby Sorunome » Sat Jan 21, 2017 3:50 pm
Have you installed the normal AVR boards via the board manager?
If not, try using a different USB port......USB can be weird like that
Postby Aisjam » Sun Jan 22, 2017 3:06 am
currently Have Arduino AVR Boards 1.6.17 Installed. I have used my main development usb (has the data connector in there) plus 5 others. the main thing i keep reading is that yosmite has included their own data transfer and clashes with D2xx. i have removed apples one but still no luck, my other arduinos connect fine though.
is there another way i could test the usb connector on the gamebuino to make sure that isn't the problem?
Aisjam
Postby Sorunome » Sun Jan 22, 2017 9:45 am
Ooooh, are you using the micro usb cable that shipped with it? Not all allow data transfer, some only allow charging. So try a different cable ^.^
