wuuff wrote:The game is fun and has a really interesting and nice aesthetic. The levels feel a little strange, like the pieces that are put together are placed sort of haphazardly, but I think that's an interesting design decision and not a problem.
wuuff wrote:I find the small bounce that the player does when falling from a high height a bit annoying because it prevents quick jumps after landing (and results some frustrating deaths), but it provides a challenge and I think that's another justifiable design decision.
I became better and better before creating the first level, while i was working on This is why the difficulty curve is very weird and that the last level we need to perform trick such as "retrieve wall jump"(Wall jump and stop pressing the arrows for climbing walls) and "extreme wall prupulsion"(Swipe very fast on the other side for max propulsion after wall jumping). It seem unfair but the hole game is possiblewuuff wrote:The game is pretty hard, but since it isn't super long, that might be fine. I haven't made it past the fourth level, though. It's very frustrating to play because it requires a lot of precision and sometimes movement feels a little finicky. The game is really cool, and I think people willing to put the time in to master the levels will have a lot of fun. I'm sure I'll keep retrying the levels until I can beat them. However, it maybe feels a little more unfair than it needs to.
wuuff wrote:If I go off the top of the level in level 3, it shows the game's ending cutscene, which seems like a weird bug.
for(int yd; yd < 8; yd++) { //yd = Y Down
ColY[yd] = PixelInCollider((-(floor((PPosX - 3 + yd) / 8.0))) , (-(floor((PPosY - 4 + 0) / 8.0))) , -(-(PPosX - 3/*e3*/ + yd) - (-(floor((PPosX - 3/*e3*/ + yd) / 8.0)))*8) , -(-(PPosY - 4/*e4*/ + 0) - (-(floor((PPosY - 4/*e4*/ + 0) / 8.0)))*8));
jonnection wrote:Important message to the author of this game:
You have a bad programming habit that is going to get you into alot of trouble.
You are declaring local variables (int yd; yd < 8; yd++) <-- in this case yd and then using them without giving them an initial value.
The proper way is --> for(int yd=0; yd < 8; yd++)
This is because in some C/C++ compilers, the value of yd is indetermined. You are assuming it is zero, and probably in Arduino it is, but in all other C compilers the initial value of yd can be anything. And your code will break. I discovered this playing BBB on the Pokitto.
EDIT: the reason why I call it a "bad programming habit" is because the compiler will not complain, but your code will not work properly. It is the worst kind of bug to have in a program. And you have indetermined local variable all over your code. Be aware that what happens with such variables is completely random on some C/C++compilers.
Here's a link that explains it:
http://stackoverflow.com/questions/1597 ... ve-a-value
Otherwise a really nice game! like the style very much.
Sorunome wrote:I just tried this game and it is quite fun!
However, I found it a bit slow so i pushed the framerate from 20FPS to 30FPS and it is even more enjoyable now IMO ^.^
EDIT: bug report!
In the third level, the one where the keys are introduced, you can finish the level in a shortcut: On the rightmost key you jump up the shaft, stand (outside of the screen) on that right pillar thing and then jump in an up/right-ish direction and then it'll say you passed the level and it'll unlock the next level
EDIT2: Stuff like this probably isn't supposed to happen, either.... https://www.youtube.com/watch?v=wRJ2vbAwSfk it is helpful, though! :3
STUDIOCRAFTapps wrote:Sorunome wrote:I just tried this game and it is quite fun!
EDIT: bug report!
I won't fix that bug... Because i like to glitch-out in game. You remember the minus level in SMB? It's so fun to discover new things that are not supposed to happen!
Users browsing this forum: No registered users and 70 guests
