[solved] TilemapRamino example
Re: TilemapRamino example
Postby Duhjoker » Sun May 28, 2017 1:36 am
ok lets break the function down...
hese are the definitions.....
boolean Grafx_esp::getBitmapPixel(const uint8_t* bitmap, uint16_t x, uint16_t y) {
   return pgm_read_byte(bitmap + 2 + y * ((pgm_read_byte(bitmap) + 7) / 8) + (x >> 3)) & (B10000000 >> (x % 8));
void Grafx_esp::drawTilemap(int x, int y, const uint8_t *tilemap, const uint8_t **spritesheet, uint16_t color) {
   drawTilemap(x, y, tilemap, spritesheet, 0, 0, Grafx_TFTWIDTH, Grafx_TFTHEIGHT, color);
void Grafx_esp::drawTilemap(int x, int y, const uint8_t *tilemap, const uint8_t **spritesheet, uint16_t dx, uint16_t dy, uint16_t dw, uint16_t dh, uint16_t color) {
   uint16_t tilemap_width = pgm_read_byte(tilemap);          //    tilemap width
   uint16_t tilemap_height = pgm_read_byte(tilemap + 1);    //  tilemap height  what is the +1
   uint16_t tile_width = pgm_read_byte(tilemap + 2);           //tile width      what is +2
   uint16_t tile_height = pgm_read_byte(tilemap + 3);         // tile  height    what  +3
   tilemap += 4; // now the first tiyleis at tilemap
   uint16_t ddw = dw + dx;
   uint16_t ddh = dh + dy;
   uint16_t maxDdx = (dw - x + tile_width - 1) / tile_width;
   uint16_t maxDdy = (dh - y + tile_height - 1) / tile_height;
   if (tilemap_width < maxDdx) {
      maxDdx = tilemap_width;
   if (tilemap_height < maxDdy) {
      maxDdy = tilemap_height;
   int16_t startDdx = (-x) / tile_width;
   int16_t startDdy = (-y) / tile_height;
   if (startDdx < 0) {
      startDdx = 0;
   if (startDdy < 0) {
      startDdy = 0;
   if (flagcollision)numcolision = 0;                                 //Line 735 - clear numcolision - ADD by Summoner123
   for (uint16_t ddy = startDdy; ddy < maxDdy; ddy++) {          //what are these ++
      for (uint16_t ddx = startDdx; ddx < maxDdx; ddx++) {    what are these ++
         int16_t drawX = ddx*tile_width + x + dx;
         int16_t drawY = ddy*tile_height + y + dy;
         uint16_t tile = pgm_read_byte(tilemap + ddy*tilemap_width + ddx);
         if (drawX >= dx && drawY >= dy && drawX <= (ddw - tile_width) && drawY <= (ddh - tile_height)) {
            drawBitmap1(drawX, drawY, spritesheet[tile], tile_width, tile_height, color);
            if (flagcollision) {
               solid[numcolision].x = drawX;                     //Save X coordinate      - ADD by Summoner123
               solid[numcolision].y = drawY;                     //Save Y coordinate      - ADD by Summoner123
               solid[numcolision].spritecol = spritesheet[tile]; //Save Sprite of tile    - ADD by Summoner123
               numcolision++;                                    //Increment numcolision  - ADD by Summoner123
         else { // we need to draw a partial bitmap
            drawBitmapTm(drawX, drawY, tile_width, tile_height, spritesheet[tile], dx, dy, dw, dh, color);
void Grafx_esp::drawBitmapTm(int16_t x, int16_t y, int16_t w, int16_t h, const uint8_t *bitmap, uint16_t dx, uint16_t dy, uint16_t dw, uint16_t dh, uint16_t color) {
   int16_t i, j, byteWidth = (w + 7) / 8;
   dw += dx;
   dh += dy;
   int16_t largest = 0;
   int16_t largesty = 0;
   for (j = 0; j < h; j++) {
      for (i = 0; i < w; i++) {
         if (pgm_read_byte(bitmap + j * byteWidth + i / 8) & (B10000000 >> (i % 8))) {
            int16_t drawX = x + i;
            int16_t drawY = y + j;
            if (drawX >= dx && drawX < dw && drawY >= dy && drawY < dh) {
               drawPixel(drawX, drawY, color);
Postby awesome101 » Sun May 28, 2017 1:43 am
To be honest, I think you should just write your own tile map algorithm because this is a little complicated. If the bit maps are displayed fine anywhere on the screen, then I think the problem is with the drawTilemap() function.
awesome101
Postby awesome101 » Sun May 28, 2017 1:51 am
for(unsigned int y = 0; y < 15; y++) {
for(unsigned int x = 0; x < 20; x++) {
Int tile = pgm_read_byte(data + (x + y * 20));
drawBitmap(x * 16, y * 16, tile);
awesome101
Something like that
awesome101
Postby awesome101 » Sun May 28, 2017 1:54 am
replace the drawTilemap function with something like that and it should work
Edit:
Duhjoker I can't help you if you keep leaving like this, try the code above and quickly tell me if it works I'm trying to diagnose the problem
awesome101
Postby Duhjoker » Sun May 28, 2017 2:11 am
Where exactly do I add that?
Postby awesome101 » Sun May 28, 2017 2:12 am
In the drawTilemap() function
awesome101
Postby awesome101 » Sun May 28, 2017 2:16 am
void Grafx_esp::drawTilemap() {
int tile = pgm_read_byte(tilemap_black + (x + y * 20));
awesome101
Postby awesome101 » Sun May 28, 2017 2:18 am
When you call the function in your sketch, pass in no arguments
awesome101
Postby awesome101 » Sun May 28, 2017 2:24 am
Did it work??
Hello?
awesome101
