SD card, does it poke out?
Talk about (almost) anything
Postby zerosimms » Thu May 01, 2014 6:29 pm
Out of curiosity, does anyone know if the SD card will poke out when it's inside the gamebuino or will it sit flush?
zerosimms
Re: SD card, does it poke out?
Postby adekto » Thu May 01, 2014 6:31 pm
its micro sd it has to be flush
Postby zerosimms » Thu May 01, 2014 6:50 pm
Thanks adekto
Makes getting it in and out of the pocket a lot easier :)
zerosimms
Postby Myndale » Thu May 01, 2014 11:20 pm
Actually it's a spring-loaded socket so the card extends about 2 mm out, which it needs to do so that you can remove it by pressing down.
Postby adekto » Thu May 01, 2014 11:29 pm
can you make a picture since now im not sure if its flush with the pcb or not
Postby Myndale » Fri May 02, 2014 9:17 am
Posting links because the images are too big to inline:
http://imgur.com/8wdjLX9,U3iG2rL#0
http://imgur.com/8wdjLX9,U3iG2rL#1
Postby zerosimms » Fri May 02, 2014 9:21 am
That's not bad actually, I guess a case would allow you to streamline it more if you so wish.
zerosimms
Postby rodot » Fri May 02, 2014 12:05 pm
Here are picture of gamebuino rev1 (early bird's version). The micro is protected by the acrylic case.
Postby zerosimms » Fri May 02, 2014 12:22 pm
Perfect! Thanks for the screenies!
zerosimms
Return to General forum
Users browsing this forum: No registered users and 71 guests
