Frogger by GB Community & Ripper121
Postby ripper121 » Mon Jun 23, 2014 1:50 pm
So the next game i like to create is frogger.
Atari 2600 Frogger
If someone like to help me, i need some graphics.
Frog, Cars, etc....
First test code with no output.
//importe the Gamebuino library
// Game constants
boolean paused = false;
//Game Speed
unsigned long prevTime = 0;                        // for gamedelay (ms)
int delayTime = 500;                               // Game step in ms
typedef struct
  char x;
  char y;
  byte w;
  byte h;
}  player;
player Frogg;
typedef struct
  char x;
  char y;
  byte w;
  byte h;
}  enemy;
  gb.startMenu(F("Frogger by Ripper121"));
  initGame();
void loop(void)
  if (gb.update()) {
    if (gb.buttons.pressed(BTN_C)) {
      paused = !paused; //toggle paused state
    if (!paused) {
      if (gb.buttons.pressed(BTN_LEFT)) {
      if (gb.buttons.pressed(BTN_RIGHT)) {
      if (gb.buttons.pressed(BTN_UP)) {
      if (gb.buttons.pressed(BTN_DOWN)) {
      unsigned long currentTime = millis();
      if (currentTime - prevTime >= delayTime) {
        nextstep();
        prevTime = currentTime;
    draw();
void initGame() {
  //Game Speed
  delayTime = 200;                     // Game step in ms
  randomSeed(millis());
void draw() {
  gb.display.drawFastVLine(0, 0, LCDHEIGHT);
  gb.display.drawFastHLine(0, 0, LCDWIDTH);
  gb.display.drawFastVLine(LCDWIDTH-1, 0, LCDHEIGHT);
  gb.display.drawFastHLine(0, LCDHEIGHT-1, LCDWIDTH);
void nextstep() {}
ripper121
Re: Frogger by Ripper121
Postby treflip » Mon Jun 23, 2014 6:17 pm
How do I help? I like frogger.
treflip
Postby treflip » Mon Jun 23, 2014 6:37 pm
Will these work? I just did them during lunch.
treflip
Postby Drakker » Mon Jun 23, 2014 8:44 pm
Almost 16x16 is waaay too big... the screen is 48 px high. Do you plan to scroll the screen once the frog reaches the river? If so, maybe the cars could be something like 6x6 or 8x6.
Drakker
Postby treflip » Mon Jun 23, 2014 8:51 pm
Ahh, that makes sense. I thought I read somewhere someone said 16x16 is good for sprites. I'll have to adjust it later today for 8x8 or something proportional to the road. Also I was thinking of making the automobiles white if the road will be black??? Thanks!
treflip
Postby ripper121 » Mon Jun 23, 2014 9:34 pm
It can also 8x10 or 5x6 pixel ;).
Black is good the road is white.
Thanks for your help :)
ripper121
Postby treflip » Mon Jun 23, 2014 9:48 pm
No problem. I need to start somewhere!
Here's the dimensions I am thinking for my parameters.
The white is for measuring: Inside the grey area is 84 x 48 - so the top green is 5 pixels tall for the landing across after passing over the logs; the water is 25 pixels tall; the road is 20 pixels tall - which breaks into three lanes (6 pixels ea.) and takes about two hops per lane to get across. The cars are like Drakkar said 4 x 6.
Let me know if this is good and I'll finish up the cars/logs, spiders, tomorrow during lunch!
treflip
Postby ripper121 » Mon Jun 23, 2014 10:02 pm
Yes looks great.
Pleas only black and white, grey is at the moment no so well
ripper121
Postby treflip » Tue Jun 24, 2014 3:13 pm
Ok, the colored window was just to differentiate between the segments easier. Here's what it will actually look like.
and here should be the images for cars, logs, flowers, alligators.
Notes:
The cars move one way on the outer lanes and the opposite way in the middle.
The alligators have 4 images for moving the mouth and loop back to the first.
....The first alligator image is for when the frog needs to jump across quickly and won't kill it but the other 3 will.
The misc images on the right are flowers.
The bottom right img's are the frog. The middle blinks so the player can reference where it is quicker.
Not sure if the frog size will be an issue with the flowers let me know if it needs a little tweaking and I'll get it fixed.
treflip
Postby rodot » Tue Jun 24, 2014 3:27 pm
You can attach images to your post and insert them inline, so please don't host them somewhere else. Your links are broken.
Users browsing this forum: No registered users and 22 guests
