Sorunome wrote:The only place i could find the install was in the start menu under programs, running that did.......nothing
Grahack wrote:But then, the sim doesn't launch. a search on the computer found some appcrash dirs.
Grahack wrote:But then, you can't decide where to install.
Myndale wrote:Sorry to hear about the install problems you've been having, not quite sure what's going on there. I've just pushed a standalone build to the Simbuino binaries folder, you might have better luck with that:
https://github.com/Myndale/Simbuino/raw/master/binaries/Simbuino-Standalone.zip
Clifford wrote:I have downloaded the source and was going to try in in the debugger - but the library dependencies are not included in the package, and I have not yet had time to sort it all out. Will report back when I have made some progress.
An exception of type 'System.TypeInitializationException' occurred in Simbuino.UI.dll but was not handled in user code
Additional information: The type initializer for 'Simbuino.UI.Audio.AudioPlayer' threw an exception.
AudioPlayer.Filtered = Simbuino.UI.Properties.Settings.Default.AudioFiltered;
AudioPlayer.Start();
Users browsing this forum: No registered users and 26 guests
