Forum › Hardware Development
Gamebuino sound output
cyberic Mon May 18, 2015 8:48 am
Hello!
I'd like to know which pin is used for sound output.
Is this documented somewhere?
And another question:
Does Gamebuino library use Timer1 and Timer2?
I'd like to use a library that use them as well, so is there a risk of confilct?
Thanks
Eric
Sorunome Mon May 18, 2015 11:36 am
As far as I know the gamebuino library uses all of Timer1 through Timer4 for various things, including sounds and other.
You can find the schematics of the gamebuino here: http://gamebuino.com/wiki/index.php?title=Hardware
cyberic Mon May 18, 2015 12:01 pm
Sorunome wrote:You can find the schematics of the gamebuino here: http://gamebuino.com/wiki/index.php?title=Hardware
Ha yes sorry I overlooked the document.
Sorunome wrote:As far as I know the gamebuino library uses all of Timer1 through Timer4 for various things, including sounds and other.
Thanks
Is it documented somewhere or should I look at the source code?
Sorunome Mon May 18, 2015 1:57 pm
Thanks
I am not sure about this, but you'll probably find answers in the gamebuino library source.
rodot Thu May 28, 2015 5:34 pm
The buzzer is connected to the pin PD3/INT1/OC2B/PCINT19 of the Atmega328, which is the Arduino pin 3 (pwm).
All the atmega328 timers are used by both Arduino and the Gamebuino library:
Timer 0 is for Arduino functions like delay(), millis() and micros(), which are used by the Gamebuino library for timing (framerate regulation and alike).
Timer 1 is used to generate interruptions to update the sound waveform at about 57Khz (it might seem high but it's to manage accurate sound frequency and not to be off-tune)
Timer 2 is used to generate 30Khz PWM output to the pin 3 as a DAC of sound generation
More info about arduino, timers and interruptions : http://letsmakerobots.com/content/arduino-101-timers-and-interrupts
If you disable the sound engine by changing
#define NUM_CHANNELS 1
to
#define NUM_CHANNELS 0
in the file settings.c in the Gamebuino library folder, you should be able to use libraries that require timer 1 or 2.
You're not asking for it, but some people might be interested by the Sound page of the wiki which explains how the sound library works (but there is no composer yet...)
