Maximum loop runs?
wwtom Sun Jul 19, 2015 4:10 pm
I want to calculate with 3d points.
So I need to try pretty, pretty many points!
And many points = many loops ^^
This is my actual try to test a 64x64x64 room with 0,5 accuracy.
This means 2359296 loop runs per "aS".
I could understand if it would take really long, but it just does nothing. If I fill something like i ++ in the middle, i is 0 at the end :(
Is there any way to make this work? No problem if its really slow. It already takes about 0,5 min to check the 64x64x64 room with 1 accurancy.
for(int ix = SpC[0] - 32; ix < SpC[0] + 32; ix ++){
for(int iy = SpC[1] - 32; iy < SpC[1] + 32; iy ++){
for(int iz = SpC[2] - 32; iz < SpC[2] + 32; iz ++){
for(int igx = ix; igx < ix + 1; ix = ix + 0,5){
for(int igz = iz; igz < iz + 1; iz = iz + 0,5){
for(i = 0; i < aS; i++){
jonnection Sun Jul 19, 2015 4:29 pm
You can't add 0,5 to an integer (int). The result will be zero all the time.
Proof:
http://goo.gl/TASJm3
Output:
"x: 0.0000"
Proof:
#include <stdio.h>
int main()
int x=0;
x = x + 0,5;
printf("x: %f \n",(float)x);
return 0;
Output:
"x: 0.0000"
wwtom Sun Jul 19, 2015 4:47 pm
Oh man D:
Thank you :o
Thank you :o
