Forum › Programming Questions
Sound Library error
agentavacado Sat Jul 25, 2015 1:23 pm
Hello, I have researched the "Programming Questions" section of the four for any "Error compiling." errors and could find none. It seems that there is an error with the following code(copied right from the reference area):
static unsigned const char PROGMEM logo[]=
  8,8,
  B00000000,
  B00100100,
  B00011000,
  B01111110,
  B00111100,
  B01111110,
  B00111100,
  B00000000,
  gb.titleScreen(F("Example game"), logo);
    gb.display.println("Hello world");
The reason i'm posting this on the gamebuino forums and NOT the arduino forums is because it seems that there is a problem with the Sound part of the gamebuino library.
/Users/_/Documents/Arduino/libraries/Gamebuino/Sound.cpp: In member function 'void Sound::begin()':
/Users/_/Documents/Arduino/libraries/Gamebuino/Sound.cpp:62:2: error: 'TCCR2B' was not declared in this scope
  TCCR2B = (TCCR2B & B11111000) | 1; //set timer 2 prescaler to 1 -> 30kHz PWM on pin 3
/Users/_/Documents/Arduino/libraries/Gamebuino/Sound.cpp: In static member function 'static void Sound::updateOutput()':
/Users/_/Documents/Arduino/libraries/Gamebuino/Sound.cpp:563:2: error: 'OCR2B' was not declared in this scope
  OCR2B = output; //60x faster than analogOutput() !
Error compiling.
Did I skip a step?
rodot Sat Jul 25, 2015 3:20 pm
Did you select Gamebuino in tools/board ? What version of Arduino are you running, on which operating system ?
