[SOLVED]gamebuino does not name a type
EatMyBlitch Fri Aug 07, 2015 10:36 am
Hello everyone,
In Arduino ERW 1.0.5 every time i try and load an example to my gamebuino it says:
Gamebuino does not name a type.
and allot of:
gb was not declared in this scope ,
and LCDWIDTH was not declared in this scope
the same with all the other LCD dimensions.
I have this problem with every single example.
:cry: :cry: :cry: :cry:
Sorunome Fri Aug 07, 2015 10:39 am Re: gamebuino does not name a type
Did you make sure this are your first three lines?
Did you make sure you have all the library files copied over correctly?
Do you have as board selected "Gamebuino" ?
EatMyBlitch Fri Aug 07, 2015 10:43 am Re: gamebuino does not name a type
those are my first 3 lines but i cant seem to find Gamebuino in the board list.
Sorunome Fri Aug 07, 2015 10:44 am Re: gamebuino does not name a type
Then you didn't copy over the folders correctly, check out http://gamebuino.com/wiki/index.php?tit ... ware_setup
EatMyBlitch Fri Aug 07, 2015 10:46 am Re: gamebuino does not name a type
i did it wil test out now
EatMyBlitch Fri Aug 07, 2015 10:48 am Re: gamebuino does not name a type
thanks alot sorunome :lol: :lol:
Sorunome Fri Aug 07, 2015 10:48 am Re: gamebuino does not name a type
No problem!
Mind editing the first post to add "[solved]" in front of the title so that others know it is solved?
EatMyBlitch Fri Aug 07, 2015 10:49 am Re: gamebuino does not name a type
ok will do
