gb.display.println() likes to fill screen with random chars
agentavacado Sat Aug 22, 2015 5:04 pm
I was trying to make a custom menu function, and then... Something odd happened... The function would act a lot like the average gb.menu() but I wanted to make custom graphics. So I started work on it, this is what I came up with:
I tried calling it with this array:
And the screen filled up with random numbers, symbols, and even words from the previous time it was called.
Creepypasta material.
When the menu is called it appears to work, saying "Test 1" in the box, but when you move your cursor...
I can't show you the image directly but here is a dropbox link:
After moving the cursor(it changes every second or so):
https://www.dropbox.com/s/n7s88qfkyscyvyc/Gamebuino%20bug%20after%20pressing%20a%20button.jpg?dl=0
static unsigned const char PROGMEM ArrowRight[]=
8,5,
B11100,
B11110,
B11111,
B11110,
B11100,
const byte GBMenuSelect[] PROGMEM = {64,16,
0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,
0x40,0x0,0x0,0x0,0x0,0x0,0x0,0x2,
0x80,0x0,0x0,0x0,0x0,0x0,0x0,0x1,
byte Menu(byte Length, String allElements[]) {
//Length is 0 based
boolean Exit = false;
byte menuCursor = 0;
byte menuSelected;
//Delay, since a bug would prevent a second menu to be called(well, it would be skipped)
int FrameDelay = 0;
while (!Exit) {
if (gb.update()) {
FrameDelay++;
if (FrameDelay >= 20) Exit = true;
gb.display.drawPixel(0, FrameDelay);
Exit = false;
while (!Exit) {
if (gb.update()) {
gb.display.drawBitmap(0, 22, ArrowRight);
gb.display.drawBitmap(10, 17, GBMenuSelect);
//Temp, it should be A and B, not B and C
gb.display.println("Press \"B\" to select");
gb.display.print("\"C\" to Return");
PrintHere(12, 24);
gb.display.print(allElements[menuCursor]);
PrintHere(0, 0);
if (gb.buttons.pressed(BTN_UP)) {
byte menuCursorDes = menuCursor + 1;
if (menuCursorDes <= Length) menuCursor++;
if (gb.buttons.pressed(BTN_DOWN)) {
byte menuCursorDes = menuCursor - 1;
if (menuCursorDes >= 0) menuCursor--;
if (gb.buttons.pressed(BTN_B)) {
Exit = true;
menuSelected = menuCursor;
if (gb.buttons.pressed(BTN_C)) Exit = true;
return menuSelected;
byte PAtt1 = 1;
byte PAtt2 = 0;
byte PAtt3 = 0;
byte PAtt4 = 0;
String NameAtt(byte Attack) {
String AttackName = "Unknown";
if (Attack == 0) AttackName = "Nothing";
if (Attack == 1) AttackName = "Test 1";
if (Attack == 2) AttackName = "Test 2";
return AttackName;
String AllAttacks[] = {NameAtt(PAtt1), NameAtt(PAtt2), NameAtt(PAtt3), NameAtt(PAtt4)};
agentavacado Wed Aug 26, 2015 2:08 am Re: gb.display.println() likes to fill screen with random ch
Since nobody has responded yet... It's rather nobody can figure out what's wrong with this code or you guys are in awe because the code error is so obvious and I can't see it. So I decided to fix a few things:
I changed the button inputs, and most importantly, an if statement that catches NULL and prints "Null!" instead of NULL.
It didn't fix anything.
Since I'm using a byte for menu cursor... If it goes under 0 it will jump to 255(which should be NULL, which I thought I protected, which I just realized... I'll fix it). But here's a small update. If it helps. Could it just be my gamebuino?
//Length is 0 based
byte menuSelected;
//Custom delay
int FrameDelay = 0;
while (!Exit) {
if (gb.update()) {
FrameDelay++;
if (FrameDelay >= 10) Exit = true;
//Shows that it's working
Exit = false;
while (!Exit) {
if (gb.update()) {
gb.display.println("Press \"A\" to select");
gb.display.print("\"B\" to Return");
PrintHere(12, 24);
if (allElements[menuCursor] != NULL) {
} else {
gb.display.print("Null!");
PrintHere(0, 0);
int menuCursorDes = menuCursor - 1;
if (menuCursorDes <= 0) menuCursor--;
int menuCursorDes = menuCursor + 1;
if (menuCursorDes >= Length) menuCursor++;
if (gb.buttons.pressed(BTN_A)) {
Exit = true;
if (gb.buttons.pressed(BTN_B)) Exit = true;
Sutchig Wed Aug 26, 2015 9:52 am Re: gb.display.println() likes to fill screen with random ch
i have only uneducated guesses ;)
in
you test if menuCursorDes is _below_ or equal 0 an then make menuCursor one smaller. So if menuCursor is 0, then menuCursorDes becomes -1 -> and menuCursor will be 255
should do it (???)
For BTN_DOWN ist the same.
and I dont know, if allElements[menuCursor] != NULL really works...
in
if (menuCursor > 0) menuCursor--;
should do it (???)
agentavacado Wed Aug 26, 2015 8:49 pm Re: gb.display.println() likes to fill screen with random ch
You are correct with the byte jump, I changed menuCursor and menuCursorDes to int so the problem shouldn't be there anymore. I don't know what an empty array slot is... I thought it was NULL, but then again it should then be array out of bounds... Knowing this I'll fix my code and report back!
agentavacado Wed Sep 02, 2015 1:31 am Re: gb.display.println() likes to fill screen with random ch
I'm back with a working Menu(byte, String[]) function. I did do a few things to avoid bugs. The customDelay(int) function is just the 10 frame delay code from the last version.
There should be more security for the println function.
Obviously this menu is pretty boring so I'll be adding some things to it before the final product.
//Length is 0 based
byte menuSelected;
customDelay(10);
while (!Exit) {
if (gb.update()) {
PrintHere(12, 24);
if (allElements[menuCursor] != allElements[Length + 1]) {
} else {
gb.display.print("Empty!");
PrintHere(0, 0);
customDelay(2);
if (menuCursor < Length) menuCursor++;
customDelay(2);
Exit = true;
