Forum › Hardware Development
How to add a IR light?
Florens Thu Sep 17, 2015 5:40 pm
I'm the biggest arduino hardware noob in the world and I have no Idea how I'm suposed to add a simple IR led. Do I use the I2C ports and how do I use them?
Sorunome Fri Sep 18, 2015 7:53 am
It totally depends on the kind of IR controller you have, if that controller is accessible over the I2C protocol that would sure be the simplest solution.
jonnection Fri Sep 18, 2015 9:02 pm
If the Gamebuino had an audio jack, this would be a simple task.
You would simply stick an IR led in the audio output, disable audio from the Gamebuino lib, and use the Arduino IR library. Basically you'd be making a "sound" at 38 kHz (IR signal frequency) and modulate that, just as the PWM sound of the Gamebuino is made. That'll cost you 0.2 USD
Or
Buy an "I2C IR transmitter" and stick it in the I2C. Unfortunately, the only one I found is CtrlIM by ThingM and costs 21.95 USD
http://microcontrollershop.com/product_info.php?products_id=5002
