Forum › Programming Questions
[SOLVED] Collision Between Bitmaps
Reocha Wed Oct 28, 2015 8:25 pm
Please help I am making a game but I'm kind of a noob so I have no idea what I am doing so PLEASE help, I'm trying to make collision between the man and the tree bitmaps and when the man hits the tree he stops. I've tried everything I know (not much) to get this to work but it wont work :(
#define MENULENGTH 2
const char strHS[] PROGMEM = "Resume";
const char strGM[] PROGMEM = "Boot Loder";
const char* const menu[MENULENGTH] PROGMEM = {
  strHS,
  strGM,
const byte Man[] PROGMEM = {16,12,
0x3F,0x0,
0x4C,0x80,
0xFF,0xC0,
0x52,0x80,
0x40,0x80,
0x7F,0x80,
0x3F,0x0,
0x3F,0x0,
0x3F,0x0,
0x3F,0x0,
0x21,0x0,
0x21,0x0,
const byte tree[] PROGMEM = {16,16,
0x3,0xC0,
0x7,0xE0,
0xF,0xF0,
0x1F,0xF8,
0x3F,0xFC,
0x3F,0xFC,
0x1F,0xF8,
0xF,0xF0,
0x7,0xE0,
0x3,0xC0,
0x3,0xC0,
0x3,0xC0,
0x3,0xC0,
0x3,0xC0,
0x3,0xC0,
0x3,0xC0,
int man_x = LCDWIDTH/2;
int man_y = LCDHEIGHT/2;
int man_vx = 3;
int man_vy = 3;
int man_size = 8;
int game_level = 1;
  gb.collideBitmapBitmap(3, 3,Man, 0, 0, tree);
     gb.display.println((man_x));
     gb.display.println((man_y));
    gb.display.drawBitmap((man_x),(man_y),Man,NOROT,NOFLIP);
    gb.display.drawBitmap(57,18,tree,NOROT,NOFLIP);
    if(gb.buttons.repeat(BTN_RIGHT,2)){
      man_x = man_x + man_vx;
      gb.sound.playTick();
      man_x = man_x - man_vx;
      man_y = man_y + man_vy;
      man_y = man_y - man_vy;
      gb.popup(F("THIS IS A TEST!"), 200);
     switch(gb.menu(menu, MENULENGTH)){
    case -1: //nothing selected
      gb.titleScreen(F("Reocha's EPIC Game... hopefully"));
      break;
    case 0: //display system info
      break;
    case 1:
      gb.changeGame();
      break;
    default:
      break;
    if(man_x < 0){
      man_x = 0;
    if((man_x + man_size) > LCDWIDTH){
      man_x = LCDWIDTH - man_size;
    if(man_y < 0){
      man_y = 0;
    if((man_y + man_size) > LCDHEIGHT){
      game_level = LCDHEIGHT - man_size;
Thanks :D
Risike Tue Nov 03, 2015 11:26 am Re: [HELP] Collision Between Bitmaps
The collideBitmapBitmap methods returns a boolean. True if it collides, False if not.
You must use :
if(gb.collideBitmapBitmap(..............){
// Do something
Reocha Thu Nov 12, 2015 9:48 pm Re: [HELP] Collision Between Bitmaps
Risike wrote:The collideBitmapBitmap methods returns a boolean. True if it collides, False if not.
You must use :
// Do something
thank you!!
