Calculator keyboard problem
awesome101 Sat Nov 14, 2015 12:36 am
I'm working on a side project of a calculator. I don't know why my code isn't working.
The while loop is for debugging purposes by the way, so that the next frame it won't display another keyboard. I'm trying to convert a string typed into the keyboard into a number by checking if it's the same as a string in an array. If it is, then the number would be the index into the array. The problem is that it doesn't print "Hello World"
Here is the code:
Thanks :D
Here is the code:
#define STATE_PROMPT 0
#define STATE_KEYBOARD 1
short state = 0;
char *prompt = "*******PROMPT*******\nPress A to type a\ncommand.\nType the command\n'commands' to show\na list of commands.";
void setup()
gb.titleScreen(F("Calculator"));
char *commands[3] = {
"sin", "cos", "tan"
void loop()
if(gb.update()) {
switch(state) {
case STATE_PROMPT: {
if(!gb.buttons.pressed(BTN_A)) {
gb.display.println(prompt);
} else {
state = STATE_KEYBOARD;
break;
case STATE_KEYBOARD: {
char* command = "";
gb.keyboard(command, 4);
while(true) {
for(int i = 0;i < 3;i++) {
char other[4];
other[i] = commands[0][i];
other[3] = '\0';
if(command == (other)) {
gb.display.println("Hello World");
gb.update();
break;
Thanks :D
awesome101 Sat Nov 14, 2015 1:02 am
Nevermind, fixed it! :D
