Chat?
rodot Tue Sep 19, 2017 9:06 am
Same old question... some think a chat a must have, others don't.
What would you prefer ?
Slack ? Discord ? IRC ? Build-in chat on the website ?
...and I just made an official discord, just in case: https://discord.gg/GbSkRyU
Sorunome Tue Sep 19, 2017 9:19 am
How about all four, linnking stuff together?
There are multiple webchat <--> IRC bridges and from there on you can bridge to matrix ( https://matrix.org/ ) which opens the world to slack, glitter, discord etc.
Drakker Tue Sep 19, 2017 10:39 am
I'm fine with IRC, if it can be linked to other systems, then good. But good ol' IRC is probably more than enough.
rodot Tue Sep 19, 2017 12:41 pm
Using several chats hooked together would just waste our time linking and debugging everything (like image sharing, private channels and watnot).
IRC isn't really noob friendly I think, not really used by youngsters. At least that's the perception I have of it.
Sorunome Tue Sep 19, 2017 2:36 pm
While that is true, IMO that isn't that much time, like, after you set it up it just works. Plus you wouldn't self-code but use others code. Several chats would yield the advantage of having a greater outreach, idk.rodot wrote:Using several chats hooked together would just waste our time linking and debugging everything (like image sharing, private channels and watnot).
From what I gathered these days IRC is mainly used in the programming community. There are many web-irc chats that makes things easier, like kiwiirc, mibbit, etc. And many also use the IRCCloud app, which is supposively pretty fine
rodot Tue Sep 19, 2017 2:45 pm
All these clients look like the come straight from the 90'... I'm really more inclined to discord and other "modern" solutions (Imagine streaming Gamebuino tutorials). Any known limitation to Discord ?
Outreach isn't a problem in my opinion, nowadays you have 5 different chatting apps and it takes < 5 seconds to go to the website and create an account.
Sorunome Tue Sep 19, 2017 2:50 pm
Closed-Source proprietary, I don't think video calls are implemented yet. And that is the least place you'd search for a programming question....then again, that isn't what the chat will be fore, so not really downsidesrodot wrote:All these clients look like the come straight from the 90'... I'm really more inclined to discord and other "modern" solutions (Imagine streaming Gamebuino tutorials). Any known limitation to Discord ?
rodot Wed Sep 20, 2017 7:23 am
Sorunome wrote:Closed-Source proprietary, I don't think video calls are implemented yet. And that is the least place you'd search for a programming question....
Agreed, but you made one so I thought it would be ok, trying to live with my time ! Closed source is a good point.
IRC it is then, which modern, easy to use, free, open source client would you prefer ? I never used IRC *hides*
Zvoc47 Wed Sep 20, 2017 11:11 pm
I'd like Discord or something that records chatlogs and which has an Android app for it.
