Memory Optimization
Myndale Fri Apr 04, 2014 3:32 am
I'm going to be turning my attention to code optimization next and I just thought I'd post a couple of tricks that may help if you suspect you're running out of memory and/or code space.
If you want to see how much memory your app is using for code space and global variables then you can use the objdump utility provided with the IDE. If you go to the Arduino IDE's File -> Preferences dialog and turn on verbose output for compilation then the output window will display the location of the hex file it makes when it compiles your project, i.e. something like this:
The hex file is what gets uploaded to your Gambuino but the elf file contains information about the code that created it, and this info can be dump to a list file by running avr-objdump like this:
This will dump a whole bunch of useful info in dump.lst including a disaasembly of all routines imported into your project. Of particular interest are the text and data sections listed at the top of the file which show how much memory is being used for global variables and code, respectively:
This particular example is Rodot's AlienKiller demo, and we can see that there are 1036 (i.e. 0x40c) bytes used for global variables (half of which is the display buffer) and 22188 (i.e. 0x56ac) bytes of code. For comparison the Gamebuino has 2KB of usable RAM and 32KB for code (less 2KB being used by the boot loader). However it's also allocating 363 (0x16b) bytes for the .bss section which is globally allocated variables that aren't initialized to a particular value.
Looking at the lst file will tell you how much memory is allocated at the start-up, but you may also need to keep track of run-time usage. When a Gamebuino game starts up the global buffer is allocated at the very bottom of SRAM, the heap appears immediately after it and the stack is placed at the very top of RAM. Any calls to malloc() will cause the heap to grow "up", and any data allocated on the stack by calling functions etc will cause the stack to grow "down". If they meet up in the middle your program will either start acting weird or simply crash.
To help prevent this you can use code like this during development to keep track of the heap and stack pointers and if they get too close print an error message or something:
Here's an example to demonstrate this, the test() function calls itself recursively, increasing the stack a little each time, until finally we run out of memory:
C:\arduino-1.0.5\hardware\tools\avr\bin\avr-objcopy -O ihex -R .eeprom C:\Users\username\AppData\Local\Temp\build8635125389519731391.tmp\your_sketch.cpp.elf C:\Users\username\AppData\Local\Temp\build8635125389519731391.tmp\your_sketch.cpp.hex
C:\arduino-1.0.5\hardware\tools\avr\bin\avr-objdump -h -S -j .data -j .text C:\Users\username\AppData\Local\Temp\build8635125389519731391.tmp\your_sketch.cpp.elf > dump.lst
Sections:
Idx Name Size VMA LMA File off Algn
0 .data 0000040c 00800100 000056ac 00005740 2**0
CONTENTS, ALLOC, LOAD, DATA
1 .text 000056ac 00000000 00000000 00000094 2**1
CONTENTS, ALLOC, LOAD, READONLY, CODE
2 .bss 0000016b 0080050c 0080050c 00005b4c 2**0
ALLOC
void mem_check()
void * heap_ptr = malloc(0);
if ((!heap_ptr) || ((int)heap_ptr + 100 >= SP))
Serial.println("Out of memory!");
while (1);
free(heap_ptr);
void dump_mem()
if (heap_ptr)
free(heap_ptr);
Serial.print("heap: ");
Serial.print((int)heap_ptr);
Serial.print(", stack: ");
Serial.println(SP);
void test()
dump_mem();
mem_check();
test();
test(); // call test twice so that the compiler doesn't convert the first one to a tail call
Serial.begin(9600);
test();
rodot Fri Apr 04, 2014 12:28 pm
Thank you for this detailed explanation!
If you could add it to the page "Performance optimization" of the wiki, that'd be really cool :)
http://gamebuino.com/wiki/index.php?title=Performance_optimization
I tried to write a few things, but I'm not a badass programmer like you and my skill in English doesn't help :P
treflip Fri Jun 20, 2014 2:38 am
Yes, Thank you for your info Myndale. It is a real help!
jonnection Tue Jun 24, 2014 7:45 am
On the subject of memory optimization, I came across Andy Brown's site today.
He's provided some excellent tools for debugging AVR dynamic memory allocation, should you want to use it.
http://andybrown.me.uk/wk/2011/01/01/debugging-avr-dynamic-memory-allocation/
Andy has written a port of the STL (standard template libraries) for the Arduino, which allows Arduino coders to use vectors and other dynamic goodies.
There is an extremely interesting bit about Andy's STL implementation, which I will quote here:
...which could be VERY useful for game environment variables, which often are in the form of boolean true/false, and are a pain to pack into bytes or waste loads of space if used as single bytes.
Note that I have also ported the template specialisation of vector for bool, i.e. std::vector<bool>. This is implemented as an array of single bits that is highly efficient in its memory usage.
BurningSushi Thu Jun 11, 2015 9:07 pm
Wow, sorry about this I know it's an old post, but information like performance optimisation is quite hard to find on the wiki and I feel it's extremely important information to put on the sidebar. And if I had difficulty with it......
But honestly thanks for pointing to this page, it's going to help majorly in the future :)
Zvoc47 Tue Oct 06, 2015 3:53 pm
I like this idea. You should put those print strings into PROGMEM for more optimization for more optimization.
