Expansion module
rodot Sat Apr 19, 2014 4:26 pm
I'm starting to think about an expansion module for Gamebuino... which extra features you would like to have?
Edit: which list:
- L/R buttons
- Wireless (radio)
- RGB LEDs on the edge of the acrylic case to change the whole Gamebuino color (as the PCB is white). It could pulse red when you're about to die for example.
- Vibration motor
- 16 extra GPIO using an I2C extander (but some of them will be used to be the CS pin of SPI devices)
- 32kB of extra RAM, but it won't be directly addressable :(
- Extra screen, something like a 128x32px oled screen, so it will fit above the current screen without making a (fragile) excrescence. Could be used to display stats, text or a minimap.
- 3 axis accelerometer
- analog Joystick
Edit: which list:
- L/R buttons
- Wireless (radio)
- Vibration motor
- analog Joystick
adekto Sat Apr 19, 2014 4:50 pm
just a few, more power to create
analog stick (for the 3D games)
accelerometer
I/O expander
wireless (rf/ir/bluetooth)
accelerometer
I/O expander
hrangan Sat Apr 19, 2014 6:04 pm
a wireless module would be nice, any type (ir, bluetooth, wifi), so long as it's compact
adekto Sat Apr 19, 2014 6:32 pm
ir wil be very very cheap and easy to do also very power efficient but has line of sight issues
all the radio ones need more juice so better have an extra battery for them maybe?
also how crazy is it to have PS/2 port or a full keypad (for text adventures)
Skyrunner65 Sat Apr 19, 2014 7:10 pm
A wireless module or Light detection module (to activate the backlight automatically)!
adekto Sat Apr 19, 2014 7:26 pm
uhm light sensor is already there dude and it also is already doing the backlight thing
read the manual...
read the manual...
Drakker Sat Apr 19, 2014 7:56 pm
L/R buttons (already planned as far as I know)
Extra RAM (MOAR stuff!)
Second screen (Maybe even a color screen!)
rodot Sat Apr 19, 2014 8:00 pm
I wanted to see you ideas before I suggest mine. Here they are:
- L/R buttons
- Wireless (radio)
- Vibration motor
- analog Joystick
...most of your ideas were already on my check list, that's a good thing.
I should be able to fit all that on a small PCB that would be plugged on top of the Gamebuino. It should be about the same thickness than the Gamebuino so it will fit nicely.
I don't really see how you would add a analog pad on top of your Gamebuino? You want to have an analog joystick instead of the L/R button ? That's a weird location.
That sounds really specific I'm not sure a lot of people would use it... and nowadays keyboards are USB, not PS/2 :P
Did you even watch the trailer ?!
- L/R buttons
- Wireless (radio)
- Vibration motor
- analog Joystick
adekto wrote:analog stick (for the 3D games)
adekto wrote:also how crazy is it to have PS/2 port or a full keypad (for text adventures)
Skyrunner65 wrote:A wireless module or Light detection module (to activate the backlight automatically)!
Skyrunner65 Sat Apr 19, 2014 8:56 pm
Oh yeah, I guess you're right.
adekto Sat Apr 19, 2014 9:49 pm
wel sure everythings usb these days but that means u need a host device that supports the interfacing
for the analog stick i was more thinking of on the side similar to those extra stick on n3ds
also 2nd screen can be fun, may want to use some sort of hinges
oh what about a second speaker for stereo
is it me or is the gamebuino expansion looking allot like a nds?
erico Sat Apr 19, 2014 10:30 pm
Was a headphone jack/audio out mentioned as an expansion too?
On my own I can´t think of much as an expansion before I actually try the gamebuino.
The extra memory sounds like a nice thing.
rodot Sat Apr 19, 2014 10:52 pm
It's not really possible to add a headphone jack on the module because the sound output is not connected to the extension ports, sorry. But it's not really complicated to solder a headphone jack yourself directly on the sound output.
I will put the module on top of the Gamebuino, so that's not really possible to add a joystick there :/
rodot Sun Apr 20, 2014 12:13 pm
I figured out a neat way to add a joystick... *suspens*
I ordered all the parts to make a prototype of the expansion board, so I'll be able to work on it if I have some free time (or if I want to take a break).
adekto Sun Apr 20, 2014 1:50 pm
great to hear, cant wait
rodot Sun Apr 20, 2014 4:58 pm
Good news: rev2 of the PCB will have a connector on the right to be able to easily add a headphone jack module.
Bad news: the first batch of 20 PCB won't have it :(
adekto Sun Apr 20, 2014 9:17 pm
il take a one of your hands than, i dont mind for the jack
Hark0 Sun Apr 20, 2014 9:23 pm
rodot wrote:Good news: rev2 of the PCB will have a connector on the right to be able to easily add a headphone jack module.
Hype! :mrgreen:
DFX2KX Mon Apr 21, 2014 7:06 pm
rodot wrote:It's not really possible to add a headphone jack on the module because the sound output is not connected to the extension ports, sorry. But it's not really complicated to solder a headphone jack yourself directly on the sound output.
You could do it, but it would need a ribbon cable going around to where you wanted to put the buttons/joystick.
A fancier option would be a set of l/r buttons that replace the whole backplate and give you some extra buttons at the bottom on either side of the charging/flashing jack. it'd be screwed in, so it shouldn't move too much.
rodot Mon Apr 21, 2014 8:45 pm
The L/R buttons are going to be directly on the module, why would they need a ribbon cable? I'm not sure we talk about the same thing.
DFX2KX Tue Apr 22, 2014 4:34 pm
rodot wrote:The L/R buttons are going to be directly on the module, why would they need a ribbon cable? I'm not sure we talk about the same thing.
I was referring to sticking a joystick on it. or more buttons then just L/R. You'd have to connect to the I2C connector, then the fact it's attached with a cable would let you put it where you want it. If you just want to hook up an l/R buttons, putting them on the module itself would work fine.
Payday02 Sat May 03, 2014 9:41 pm
I know that I am kind of jumping the gun since not many people even have their gamebuinos yet, but about how much would this cost? Also when would it be available
rodot Sun May 04, 2014 7:16 pm
I have no idea yet :/ I didn't even had time to make a breadboard prototype for now. I just received the components.
Payday02 Mon May 05, 2014 2:19 am
I didn't expect you to be able to answer yet, just keep me informed if you can because this expansion sounds really promising.
Ps: If I were in your shoes I wouldn't have even ordered the parts for it yet. I would probably have gotten too distracted. You are obviously better at multi-tasking than me. lol
Skyrunner65 Sun Nov 09, 2014 9:58 pm Module Support
Perhaps you could add support for common modules in the library or a side-library that comes with the main library.
Such common modules could be Infared, headphone jack, L/R Buttons, and the Vibr- Umm, Rumble Pack.
Just a thought. :)
Just a thought. :)
Sushi Sun Nov 09, 2014 10:12 pm Re: Module Support
He took popular ideas for modules, and said he might add them later integrated or not, so expect libraries too!
rodot Mon Nov 10, 2014 7:15 pm
Skyrunner65 wrote:Perhaps you could add support for common modules in the library or a side-library that comes with the main library.
Just a thought. :)
I merged the topic you created with this one. You knew this topic as you already posted here, I wonder why you even asked the question? Please think twice before you post Skyrunner65, it's not the first time.
Montiey Sat Feb 14, 2015 1:34 am
Just a though for wireless type.. Bluetooth and WiFi are cool, but I think IR might be suitable for something as small as a gamebuino, and better suited for things with the same DIY aspect. IR also has an advantage for size, because unlike RF based coms like WiFi, IR can be driven right from a spare pin on an arduino / gamebuino. I suppose everything else between the game and IR LED would be software driven. Actually, can you even control an LED straight form the I2C ports on the gamebuino? Does anyone have an example for this?
Myndale Sun Feb 15, 2015 6:40 am
Montiey wrote:Actually, can you even control an LED straight form the I2C ports on the gamebuino? Does anyone have an example for this?
Sure! Just take the regular blink example in the IDE and change "int led = 13;" to A4 for the DA pin or A5 for the CLK pin.
Montiey Sun Feb 15, 2015 10:01 pm
Cool! is there some sort of map I could look at to see all the names (like you said; A4, A5) of all the pins available for software controlled output?
rodot Tue Feb 17, 2015 5:09 am
There is a link to the schematics on the Hardware page ;)
ClementNerma Sat Sep 05, 2015 4:04 pm
Is it possible to use a plastic component to place the analog stick near by the "C" button ?
This stick can be very useful in many games...
Else, a wireless module will be helpful to enable multiplayer, online scores, play with players of the entire world, save progress online etc. etc. ;)
A bluetooth module is less helpful because it "just" permit to play with players which are in a very limited area... In the same room for example.
What is the cost of these three modules ? If the price is too high, it's futile... I don't want to see the price of the Gameboid pass from 35 $ to 75 $ just to have a stick and a wireless controller ! But if you've continued to develop this idea, I suppose the price is not really a problem ?
Sorunome Wed Sep 09, 2015 11:09 pm
For wireless communication you could experiment around with an ESP8266, the thing is that you'd have to write custom slave I2C code for it :/
yawn Mon Dec 05, 2016 5:26 pm
rodot wrote:I'm starting to think about an expansion module for Gamebuino... which extra features you would like to have?
Edit: which list:
- L/R buttons
Seems it's already decided.
- Wireless (radio)
Wirelessness would be great, I was going to suggest that.
Sounds cool while not too costly.
- Vibration motor
No thanks!
Extra GPIO sounds cool, I could use that to trigger events in my modular synth!
I don't know what directly addressable means, extra RAM sounded sweet.
Dunno.
- analog Joystick
Why not but I'm not sure they would be that useful.
Being able to connect to other players through the Internet would be great.
naed Mon Dec 05, 2016 8:19 pm
Old topic brought back to life
If your still considering an expansion pack I'd live to see tilt sensors on the gamebuino... Could bring a whole new level to the games we create
rodot Tue Dec 06, 2016 9:15 am
You're digging deep with this topic...
You can easily add an ADXL345 accelerometer to your Gamebuino on the I2C ports:
naed Tue Dec 06, 2016 2:58 pm
Yes but selling it as an official expansion brings all the glory of tilt control to everyone who can afford the expansion pack
