Snake
ripper121 Wed Jun 18, 2014 8:09 pm
Snake by Ripper121
The player attempts to eat objects by running into them with the head of the snake. Each object eaten makes the snake longer, so maneuvering is progressively more difficult.
Controles:
Download Zip containing the source code, HEX file and ELF file:
Download
Pay what you want :)
Source Code:
Controles:
- Up = move the snake up
Down = move the snake down
Left = move the snake left
Right = move the snake right
C = Pause
- No extension module needed
Download
Source Code:
//importe the Gamebuino library
const byte logo[] PROGMEM =
64, 30,
B00000000, B00000000, B00000000, B00000000, B00000000, B00000000, B00000000, B00000000,
B00000000, B00011000, B00000000, B00000000, B00000000, B00001000, B00000000, B01110000,
B00000000, B01111000, B00000000, B00111100, B00011100, B00111000, B00010001, B11110000,
B00000000, B11111000, B00111000, B01111100, B01111100, B01111000, B00111011, B11110000,
B00000001, B11111100, B11111000, B01111100, B11111100, B11111000, B01111111, B11110000,
B00000111, B11111100, B11111100, B11111101, B11111100, B11111100, B01111111, B11000000,
B00001111, B11111000, B11111100, B11111001, B11111110, B01111101, B11111111, B10000000,
B00011111, B11100001, B11111110, B11111011, B11111110, B00111101, B11111110, B00000000,
B00011111, B10000001, B11111110, B11111011, B11011110, B11111111, B11101110, B00000000,
B00011111, B00000001, B11111110, B11111011, B11011111, B11111111, B11011110, B11100000,
B00111110, B00011110, B11101111, B01111011, B11001111, B11111111, B10001111, B11100000,
B00111111, B11111111, B11101111, B11111111, B11111111, B11111111, B11001111, B10000000,
B00111111, B11111111, B11100111, B11111111, B11111111, B10111111, B11100111, B10111000,
B00011111, B00011111, B11100011, B11110111, B11111111, B10111111, B11110111, B11110000,
B00000000, B00111110, B11100001, B11110111, B10000111, B10111110, B11110011, B11110000,
B00000000, B11111111, B11100001, B11001111, B10000011, B00011110, B01100011, B11000000,
B00000011, B11111111, B11100000, B00011111, B00000000, B00000000, B01000011, B10000000,
B00011111, B11111011, B00000000, B00000110, B00000000, B00000000, B00000000, B00000000,
B00011111, B11111000, B00000000, B00000000, B00000000, B00000000, B00000000, B00000000,
B00001111, B11100000, B00000000, B00000000, B00000011, B11111100, B11110000, B00000000,
B00001111, B00000000, B00000000, B00000000, B00011111, B11111111, B11111000, B00000000,
B00000100, B00000000, B00001111, B11111111, B11111111, B11011111, B11111000, B00000000,
B00000000, B00000001, B11111111, B11111111, B11111111, B11011111, B01111000, B00000000,
B00000000, B00000111, B11111111, B11111111, B11111111, B11111111, B11110000, B00000000,
B00000000, B00011111, B11111111, B11111111, B11111111, B11111111, B11111111, B00000000,
B00000000, B00111111, B11111111, B11111111, B11111111, B11111111, B11111111, B11000000,
B00000000, B11111111, B11111100, B00000000, B01111111, B11111111, B11111111, B11100000,
B00000000, B11111111, B00000000, B00000000, B00000111, B11011111, B11111111, B11100000,
B00000001, B11111110, B00111111, B11110000, B00000011, B11101011, B11111111, B11100000,
B00000001, B11111111, B11111111, B11111111, B11110001, B11111011, B11111101, B01100000,
const byte headL[] PROGMEM = {
5, 3,
B00100000,
B01011000,
B11110000,
const byte headR[] PROGMEM = {
5, 3,
B00100000,
B11010000,
B01111000,
const byte headU[] PROGMEM = {
3, 5,
B10000000,
B11000000,
B10100000,
B11000000,
B01000000,
const byte headD[] PROGMEM = {
3, 5,
B01000000,
B11000000,
B10100000,
B11000000,
B10000000,
const byte bodyH[] PROGMEM =
3, 3,
B01000000,
B11100000,
B01000000
const byte bodyV[] PROGMEM =
3, 3,
B01000000,
B11100000,
B01000000
const byte mouse[] PROGMEM =
8, 4,
B00001100,
B10011010,
B10111110,
B01111111
const byte apple[] PROGMEM = {
8, 8,
B00001110,
B00010000,
B01111110,
B10011001,
B10000001,
B10000001,
B01100110,
B00011000,
// Game constants
boolean paused = false;
// Direction
#define TOP 0
#define RIGHT 1
#define BOTTOM 2
#define LEFT 3
//Game Speed
unsigned long prevTime = 0; // for gamedelay (ms)
int delayTime = 500; // Game step in ms
//Snake
#define MAX_SNAKE_LENGTH 200 //needs much dynamic memmory!!!!
#define START_SNAKE_LENGTH 2
char direction = TOP; // direction of movement
typedef struct
char x;
char y;
byte w;
byte h;
byte Length;
} snake;
snake Snake[MAX_SNAKE_LENGTH];
//Food
#define FOOD_TYPES 2
#define MOUSE 0
#define APPLE 1
typedef struct
char x;
char y;
byte w;
byte h;
byte points;
byte type;
boolean exist;
} food;
food Food[FOOD_TYPES];
gb.startMenu(F("Snake by Ripper121"), logo);
initGame();
void loop(void)
if (gb.update()) {
if (gb.buttons.pressed(BTN_C)) {
paused = !paused; //toggle paused state
if (!paused) {
// if (gb.buttons.pressed(BTN_LEFT)) {
// direction--;
// if (direction < 0) {
// direction = LEFT;
// if (gb.buttons.pressed(BTN_RIGHT)) {
// direction++;
// if (direction > 3) {
// direction = TOP;
direction = LEFT;
direction = RIGHT;
if (gb.buttons.pressed(BTN_UP)) {
direction = TOP;
if (gb.buttons.pressed(BTN_DOWN)) {
direction = BOTTOM;
unsigned long currentTime = millis();
if (currentTime - prevTime >= delayTime) {
nextstep();
prevTime = currentTime;
draw();
void initGame() {
//Game Speed
delayTime = 200; // Game step in ms
randomSeed(millis());
//init snake
makesnake();
//init Food
makeFood();
void makeFood() {
for (byte i = 0; i < FOOD_TYPES; i++) {
Food[i].exist = false;
char x , y;
byte randomType = random(0, FOOD_TYPES);
if (randomType == MOUSE) {
Food[randomType].w = 8;
Food[randomType].h = 4;
Food[randomType].points = 2;
if (randomType == APPLE) {
Food[randomType].h = 8;
Food[randomType].points = 1;
x = random(0, LCDWIDTH - Food[randomType].w);
y = random(0, LCDHEIGHT - Food[randomType].h);
while (isPartOfSnake(x, y, Food[randomType].w, Food[randomType].h)) {
Food[randomType].x = x;
Food[randomType].y = y;
Food[randomType].type = randomType;
Food[randomType].exist = true;
void makesnake() {
Snake[0].Length = START_SNAKE_LENGTH; // nr of parts of snake
Snake[0].w = 4;
Snake[0].h = 4;
byte calcH = (LCDHEIGHT / Snake[0].h) / 2;
byte calcW = (LCDWIDTH / Snake[0].w) / 2;
Snake[0].x = calcH * Snake[0].h;
Snake[0].y = calcW * Snake[0].w;
for (byte i = 1; i < MAX_SNAKE_LENGTH; i++) {
Snake[i].x = 0 - Snake[0].w;
Snake[i].y = 0 - Snake[0].w;
Snake[i].w = Snake[0].w;
Snake[i].h = Snake[0].h;
Snake[i].Length = Snake[0].Length;
void draw() {
drawScore();
drawSnake();
drawFood();
gb.display.drawFastVLine(0, 0, LCDHEIGHT);
gb.display.drawFastHLine(0, 0, LCDWIDTH);
gb.display.drawFastVLine(LCDWIDTH-1, 0, LCDHEIGHT);
gb.display.drawFastHLine(0, LCDHEIGHT-1, LCDWIDTH);
void drawSnake() {
for (byte i = 0; i < Snake[0].Length; i++) {
switch (direction) {
case TOP:
if (i == 0)
gb.display.drawBitmap(Snake[i].x, Snake[i].y, headU);
else
gb.display.drawBitmap(Snake[i].x, Snake[i].y, bodyV);
break;
case RIGHT:
if (i == 0)
gb.display.drawBitmap(Snake[i].x, Snake[i].y, headR);
else
gb.display.drawBitmap(Snake[i].x, Snake[i].y, bodyH);
break;
case BOTTOM:
if (i == 0)
gb.display.drawBitmap(Snake[i].x, Snake[i].y, headD);
else
break;
case LEFT:
if (i == 0)
gb.display.drawBitmap(Snake[i].x, Snake[i].y, headL);
else
break;
void drawFood() {
if (Food[i].exist) {
if (Food[i].type == MOUSE)
gb.display.drawBitmap(Food[i].x, Food[i].y, mouse);
if (Food[i].type == APPLE)
gb.display.drawBitmap(Food[i].x, Food[i].y, apple);
void drawScore() {
gb.display.setTextSize(1);
gb.display.setCursor(2, 2);
gb.display.print(Snake[0].Length - START_SNAKE_LENGTH);
void nextstep() {
for (byte i = Snake[0].Length - 1; i > 0; i--) {
Snake[i].x = Snake[i - 1].x;
Snake[i].y = Snake[i - 1].y;
case TOP:
Snake[0].y = Snake[0].y - Snake[0].w;
break;
case RIGHT:
Snake[0].x = Snake[0].x + Snake[0].h;
break;
case BOTTOM:
Snake[0].y = Snake[0].y + Snake[0].w;
break;
case LEFT:
Snake[0].x = Snake[0].x - Snake[0].h;
break;
SnakeInPlayField();
if (isPartOfSnake(Food[i].x, Food[i].y, Food[i].w, Food[i].h) && Food[i].exist) {
Snake[0].Length += Food[i].points;
if (Snake[0].Length > MAX_SNAKE_LENGTH)
Snake[0].Length = MAX_SNAKE_LENGTH;
if (Snake[0].Length < MAX_SNAKE_LENGTH) {
makeFood();
else {
Food[i].x = Food[i].y = -1;
if (isSnakePartOfSnake()) {
gb.display.println("Game Over!");
gb.display.println();
gb.display.println("Score:");
gb.display.println(Snake[0].Length - START_SNAKE_LENGTH);
gb.display.update();
initGame();
delay(3000);
boolean isPartOfSnake(char x, char y, byte w, byte h) {
for (byte i = 0; i < Snake[0].Length - 1; i++) {
if (gb.collideRectRect(Snake[i].x, Snake[i].y, Snake[i].w, Snake[i].h, x, y, w, h)) {
return true;
break;
return false;
boolean isSnakePartOfSnake() {
for (byte i = 1; i < Snake[0].Length; i++) {
if (gb.collideRectRect(Snake[0].x, Snake[0].y, Snake[0].w, Snake[0].h, Snake[i].x, Snake[i].y, Snake[i].w, Snake[i].h)) {
return true;
break;
return false;
void SnakeInPlayField() {
if (Snake[0].x < 0) {
Snake[0].x = LCDWIDTH - Snake[0].w;
if (Snake[0].y < 0) {
Snake[0].y = LCDHEIGHT - Snake[0].h;
if (Snake[0].x > LCDWIDTH - Snake[0].h) {
Snake[0].x = 0;
if (Snake[0].y > LCDHEIGHT - Snake[0].w) {
Snake[0].y = 0;
Tiash Sat Jul 12, 2014 11:49 pm
Hi, i have played all day at this game; all the times i lost because of a "bug".
When the snake go in one direction and i accidentally click on the opposite direction, i lost :evil:
So, I look at the code. Can i suggest a solution at this bug:
In addition i have see some piece of code that can be optimized, but now is too late and i'm too tired for work on it. :)
if (gb.buttons.pressed(BTN_LEFT) && direction != RIGHT) {
direction = LEFT;
} else
if (gb.buttons.pressed(BTN_RIGHT) && direction != LEFT) {
direction = RIGHT;
} else
if (gb.buttons.pressed(BTN_UP) && direction != DOWN) {
direction = TOP;
} else
if (gb.buttons.pressed(BTN_DOWN) && direction != TOP) {
direction = BOTTOM;
ripper121 Tue Jul 15, 2014 10:33 am
Yes I know this "problem", but I thinks its not a Bug its a feature xD.
If you like to remove it then pleas compile it and post your solution, so we have 2 versions.
So the player can choose the version he like to play ;)
Tiash Tue Jul 15, 2014 11:24 am
hahaha ok i will do! :D
yodasvideoarcade Wed Jul 23, 2014 11:55 am
The game crashes after a few apples eaten. But not always at the same time. Part of the screen gets broken when this happens. Any idea? Maybe the random-placement of the fruit gets stuck?
ripper121 Wed Jul 23, 2014 2:05 pm
I my test it works fine, i dont know why becouse i cant debugg it.
