SOLVE YOUR PROBLEM - Please read, it takes 20s
rodot Sun Aug 03, 2014 10:02 am
To make this the "Installation & troubleshooting" forum easier to use we need a few simple rules:
- Read the Getting Started and Troubleshooting page it explains how to troubleshoot all the common problems.
- Search if there is already a topic about your problem. If there is, read it first it will probably solve your problem. If it doesn't post in the existing topic.
- Use a descriptive title, which allows to understand your problem even without opening the post. It's useless to use words like "please" "help me" "I'm desperate" "it's urgent". If you post here we already know that you have a problem to solve, and we'll do our best to help you out.
- Explain your problem as clearly as possible. Give us all the elements: the error message you get, how you get it, which OS you use, etc.
- Add [SOLVED] to the title of your thread when it's solved. To do so edit the first post of the thread.
nuts4ever Thu May 12, 2016 7:40 pm
Hi...
